Thanks a lot pert for your response. I´ll follow your advice. The code that Arduino IDE does not compile is the example of the pbecchi´s ESP_ping library, available at:
The complete code is the following:
Created: 05/08/2017 10:20:19
Author: pbecc
#undef PROVA_
#include <WiFi.h>
#include "ping.h"
// the setup function runs once when you press reset or power the board
const char ssid[] = "TP-LINK_C20B"; // your network SSID (name)
const char password[] = "paolo-48"; // your network password
Serial.print("Connecting t ");
Serial.println(ssid);
// WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("Pinging address: 192.168.1.1");
// the loop function runs over and over again until power down or reset
int ia[4] = { 192,168,1,1 };
int i = 0;
while (Serial.available()) {
char c = Serial.read();
delay(100);
int val = 0;
while (c != '.' && c != 10 && c!=255) {
if (c >= '0'&& c<='9') {
val = val*10+(c-'0');
c = Serial.read();
ia[i++] =val ;
IPAddress adr = IPAddress(ia[0], ia[1], ia[2], ia[3]);
Serial.printf("Ping : %d . %d . %d . %d ->", ia[0], ia[1], ia[2], ia[3]);
if (ping_start(adr, 4, 0, 0, 5))
Serial.println("OK");
Serial.println("FAILED");
delay(10000);
int readnu(char s) {
Serial.print(c);
int digit = 1,val=0;
while (c != s && c != 10&&c>0) {
if(c>'0') val += digit*(c - '0');
digit *= 10;
c=Serial.read();
Serial.print(int(c));
Serial.println(digit);
return digit;
Every time I get a error message saying: "error compiling for MH ET LIVE ESP32MiniKit board.
And the detailed error is:
Arduino:1.8.7 (Windows 10), Tarjeta:"MH ET LIVE ESP32MiniKit, 80MHz, Default, 921600, None"
D:\User\Documents\Arduino\libraries\ESP32Ping\src\ping.cpp: In function 'err_t ping_send(int, ip4_addr_t*, int)':
D:\User\Documents\Arduino\libraries\ESP32Ping\src\ping.cpp:139:45: error: 'inet_addr_from_ipaddr' was not declared in this scope
inet_addr_from_ipaddr(&to.sin_addr, addr);
D:\User\Documents\Arduino\libraries\ESP32Ping\src\ping.cpp: In function 'void ping_recv(int)':
D:\User\Documents\Arduino\libraries\ESP32Ping\src\ping.cpp:172:58: error: 'inet_addr_to_ipaddr' was not declared in this scope
inet_addr_to_ipaddr(&fromaddr, &from.sin_addr);
exit status 1
Error compilando para la tarjeta MH ET LIVE ESP32MiniKit.
