Hey there. My IDE is now not displaying code across the full width of the window. I was mid-project and as far as I'm aware didn't hit any commands to cause it.
The picture shows it better than I can probably explain it.
Has anyone encountered anything similar? I'm struggling to find a solution to get it back. I have reset my machine and reinstalled the IDE. I'm on OSX 12.2.1.
Any help would be appreciated. Cheers.
As you are using IDE version 2 I have moved your topic to a more relevant category of the forum
<Alt>+z toggles wordwrap. For some reason, on my PC, it seems you need to press it twice to take effect.
Press <Alt>+z (twice) and it should restore the wrapped lines.
Oh amazing, thank you so much that's fixed it! Was driving me nuts.
Thanks a lot ![]()
The reason for this is there are multiple word wrap modes and Alt+Z cycles through the modes:
- off - "Lines will never wrap."
- on - "Lines will wrap at the viewport width."
- wordWrapColumn - "Lines will wrap at Editor: Word Wrap Column"
- bounded - "Lines will wrap at the minimum of viewport and Editor: Word Wrap Column"
You can set it directly in the Arduino IDE advanced settings.
Thanks for the explanation, it certainly clears all.
