Arduino IDE Crashes Running Serial Monitor
Hey all,
Whenever I run the serial monitor from the Arduino IDE it either crashes the program if "Autoscroll" is checked or gets stuck with the loading wheel after the program runs for a little bit when "Autoscroll" is unchecked. The file is 15KB so I don't think it's an issue with the file but thinking maybe with the amount of data running in the serial monitor, I don't know. Whenever I run Serial Plotter it works fine though.
Notes: I'm a new user, have connected a SparkFun Microview and board via USB port, and the code I'm using is attached
_3DPrintPCR.ino (14.4 KB)
