Hello all,
I'm trying to deploy the Arduino IDE in a school.
We use Windows 7 64bit, but don't allow users access to the machine as an administrator - only as a standard user.
Problem is that the IDE itself doesn't work reliably in our environment.
When logged in as a student user we get a compiler error - the verbose error is below - arduino-builder returned 1,073,741,855 - and nothing compiles.
If I login as an administrator and run the IDE once, generally the IDE will compile, but if another user logs in at another point then sometimes the product will work, sometimes it won't - it's not predictable.
If I turn off UAC and login as an admin account the product seems to work ok, but we can't use it like this in our production set up.
I've tried adding read/write permissions to the Arudino folder in the Program Files, but no change in behaviour.
Any ideas? is there even a way we can make this work?
The verbose error is below:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "\\dma-fs-edu01\special$\EDU1TESTER\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\EDU1TE~1\AppData\Local\Temp\untitled2125743269.tmp\sketch_may26a\sketch_may26a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "\\dma-fs-edu01\special$\EDU1TESTER\Arduino\libraries" -fqbn=arduino:avr:uno -ide-version=10608 -build-path "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\EDU1TE~1\AppData\Local\Temp\untitled2125743269.tmp\sketch_may26a\sketch_may26a.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\sketch\sketch_may26a.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\sketch\sketch_may26a.ino.cpp" -o "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\sketch\sketch_may26a.ino.cpp" -o "C:\Users\EDU1TE~1\AppData\Local\Temp\buildfe53c387bd041f6c4bec836c7b21b1ce.tmp\sketch\sketch_may26a.ino.cpp.o"
Error compiling for board Arduino/Genuino Uno.
