Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS E:\Material\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: E:\Material\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': E:\Material\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 119840
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/hp/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-03-20T11:46:25.140Z root INFO Backend Object.initialize: 5.1 ms [Finished 0.623 s after backend start]
2025-03-20T11:46:25.164Z root INFO Backend Object.configure: 4.4 ms [Finished 0.623 s after backend start]
2025-03-20T11:46:25.164Z root INFO Backend s.onStart: 2.5 ms [Finished 0.623 s after backend start]
2025-03-20T11:46:25.165Z root INFO Backend s.configure: 0.4 ms [Finished 0.646 s after backend start]
2025-03-20T11:46:25.166Z root INFO Backend d.onStart: 0.3 ms [Finished 0.647 s after backend start]
2025-03-20T11:46:25.167Z root INFO Backend d.configure: 0.1 ms [Finished 0.647 s after backend start]
2025-03-20T11:46:25.168Z root INFO Backend d.initialize: 23.2 ms [Finished 0.647 s after backend start]
2025-03-20T11:46:25.168Z root INFO Backend c.onStart: 0.2 ms [Finished 0.647 s after backend start]
2025-03-20T11:46:25.169Z root INFO Backend a.configure: 24.7 ms [Finished 0.672 s after backend start]
2025-03-20T11:46:25.171Z config INFO >>> Initializing CLI configuration...
2025-03-20T11:46:25.171Z root INFO Backend c.initialize: 0.8 ms [Finished 0.672 s after backend start]
2025-03-20T11:46:25.171Z root INFO Backend x.onStart: 1.1 ms [Finished 0.673 s after backend start]
2025-03-20T11:46:25.172Z config INFO Loading CLI configuration from c:\Users\hp\.arduinoIDE\arduino-cli.yaml...
2025-03-20T11:46:25.172Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.173Z root INFO Backend a.initialize: 0.4 ms [Finished 0.674 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend w.onStart: 1.7 ms [Finished 0.675 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend r.configure: 2.4 ms [Finished 0.675 s after backend start]
2025-03-20T11:46:25.173Z discovery-log INFO start
2025-03-20T11:46:25.173Z discovery-log INFO start new deferred
2025-03-20T11:46:25.173Z root INFO Backend d.initialize: 0.5 ms [Finished 0.676 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend y.onStart: 2.2 ms [Finished 0.678 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend r.configure: 1.9 ms [Finished 0.678 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend a.onStart: 0.6 ms [Finished 0.679 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend h.configure: 0.6 ms [Finished 0.679 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend s.configure: 0.1 ms [Finished 0.680 s after backend start]
2025-03-20T11:46:25.173Z root INFO Backend l.configure: 0.1 ms [Finished 0.680 s after backend start]
2025-03-20T11:46:25.176Z root INFO Theia app listening on http://127.0.0.1:57418.
2025-03-20T11:46:25.176Z root INFO Finished starting backend application: 3.6 ms [Finished 0.683 s after backend start]
2025-03-20T11:46:25.186Z root WARN The local plugin referenced by local-dir:/c%3A/Users/hp/.arduinoIDE/plugins does not exist.
2025-03-20T11:46:25.186Z root WARN The local plugin referenced by local-dir:/c%3A/Users/hp/.arduinoIDE/extensions does not exist.
2025-03-20T11:46:25.186Z root WARN The local plugin referenced by local-dir:C:\Users\hp\.arduinoIDE\plugins does not exist.
2025-03-20T11:46:25.206Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2025-03-20T11:46:25.207Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2025-03-20T11:46:25.237Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.237Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
at Socket.<anonymous> (E:\Material\Arduino IDE\resources\app\lib\backend\main.js:2:44411)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2025-03-20T11:46:25.237Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.245Z root INFO Resolve plugins list: 73.4 ms [Finished 0.751 s after backend start]
2025-03-20T11:46:25.260Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:25.261Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:25.273Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:25.275Z daemon INFO Daemon is now listening on 127.0.0.1:57420
{"IP":"127.0.0.1","Port":"57420"}
2025-03-20T11:46:25.361Z config INFO Loaded fallback CLI configuration: {"directories":{"user":".","data":"C:\\Users\\hp\\AppData\\Local\\Arduino15"}}
2025-03-20T11:46:25.361Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":".","data":"C:\\Users\\hp\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2025-03-20T11:46:25.361Z config INFO Loaded the CLI configuration.
2025-03-20T11:46:25.361Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.361Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.361Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.367Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/hp/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2025-03-20T11:46:25.367Z config INFO Validating the CLI configuration...
2025-03-20T11:46:25.367Z config INFO The CLI config is valid.
2025-03-20T11:46:25.367Z config INFO <<< Initialized the CLI configuration.
2025-03-20T11:46:25.434Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57421
{"IP":"127.0.0.1","Port":"57421"}
2025-03-20T11:46:25.436Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.436Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.436Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.437Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57422
{"IP":"127.0.0.1","Port":"57422"}
2025-03-20T11:46:25.489Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.489Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.489Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.493Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57424
{"IP":"127.0.0.1","Port":"57424"}
2025-03-20T11:46:25.548Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.548Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.548Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.552Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57425
{"IP":"127.0.0.1","Port":"57425"}
2025-03-20T11:46:25.607Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.607Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.607Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.607Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57426
{"IP":"127.0.0.1","Port":"57426"}
2025-03-20T11:46:25.650Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.650Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.650Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.663Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:25.700Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:57427
{"IP":"127.0.0.1","Port":"57427"}
2025-03-20T11:46:25.700Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.700Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.700Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.713Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57428
{"IP":"127.0.0.1","Port":"57428"}
2025-03-20T11:46:25.757Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.757Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.757Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.757Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57429
{"IP":"127.0.0.1","Port":"57429"}
2025-03-20T11:46:25.809Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.809Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.809Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.811Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57430
{"IP":"127.0.0.1","Port":"57430"}
2025-03-20T11:46:25.878Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.879Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.879Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.879Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57431
{"IP":"127.0.0.1","Port":"57431"}
2025-03-20T11:46:25.938Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.938Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:25.938Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:25.938Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:25.945Z daemon INFO time="2025-03-20T17:16:25+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:57432
{"IP":"127.0.0.1","Port":"57432"}
2025-03-20T11:46:26.001Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.001Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.001Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.001Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:57433
{"IP":"127.0.0.1","Port":"57433"}
2025-03-20T11:46:26.052Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.052Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.052Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.053Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.057Z daemon INFO Daemon is now listening on 127.0.0.1:57434
{"IP":"127.0.0.1","Port":"57434"}
2025-03-20T11:46:26.150Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.150Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.150Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.150Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57435
{"IP":"127.0.0.1","Port":"57435"}
2025-03-20T11:46:26.203Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.203Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.203Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.203Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57436
{"IP":"127.0.0.1","Port":"57436"}
2025-03-20T11:46:26.233Z root INFO Deploy plugins list: 73.4 ms [Finished 1.740 s after backend start]
2025-03-20T11:46:26.324Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.324Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.324Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.341Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.343Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.343Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.344Z daemon INFO Daemon is now listening on 127.0.0.1:57437
{"IP":"127.0.0.1","Port":"57437"}
2025-03-20T11:46:26.389Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.389Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.389Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.415Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.419Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.420Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.422Z daemon INFO Daemon is now listening on 127.0.0.1:57439
{"IP":"127.0.0.1","Port":"57439"}
2025-03-20T11:46:26.454Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.454Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.454Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.473Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.474Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.474Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.475Z daemon INFO Daemon is now listening on 127.0.0.1:57440
{"IP":"127.0.0.1","Port":"57440"}
2025-03-20T11:46:26.504Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.504Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.504Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.524Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.525Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.525Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.527Z daemon INFO Daemon is now listening on 127.0.0.1:57441
{"IP":"127.0.0.1","Port":"57441"}
2025-03-20T11:46:26.553Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.553Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.553Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.572Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.573Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.575Z daemon INFO Daemon is now listening on 127.0.0.1:57442
{"IP":"127.0.0.1","Port":"57442"}
2025-03-20T11:46:26.605Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.605Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.605Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.621Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.621Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.621Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.623Z daemon INFO Daemon is now listening on 127.0.0.1:57443
{"IP":"127.0.0.1","Port":"57443"}
2025-03-20T11:46:26.650Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.650Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.650Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.668Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.669Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.669Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.671Z daemon INFO Daemon is now listening on 127.0.0.1:57445
{"IP":"127.0.0.1","Port":"57445"}
2025-03-20T11:46:26.709Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.709Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.709Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.727Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.728Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.730Z daemon INFO Daemon is now listening on 127.0.0.1:57447
{"IP":"127.0.0.1","Port":"57447"}
2025-03-20T11:46:26.762Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.762Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.762Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.779Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.780Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.783Z daemon INFO Daemon is now listening on 127.0.0.1:57448
{"IP":"127.0.0.1","Port":"57448"}
2025-03-20T11:46:26.808Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.808Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.808Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.824Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.825Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.826Z daemon INFO Daemon is now listening on 127.0.0.1:57449
{"IP":"127.0.0.1","Port":"57449"}
2025-03-20T11:46:26.848Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.849Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.849Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.862Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.863Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.863Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.864Z daemon INFO Daemon is now listening on 127.0.0.1:57450
{"IP":"127.0.0.1","Port":"57450"}
2025-03-20T11:46:26.886Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.887Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.887Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.903Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.904Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.905Z daemon INFO Daemon is now listening on 127.0.0.1:57451
{"IP":"127.0.0.1","Port":"57451"}
2025-03-20T11:46:26.924Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.924Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.924Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.937Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.938Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.938Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.939Z daemon INFO Daemon is now listening on 127.0.0.1:57452
{"IP":"127.0.0.1","Port":"57452"}
2025-03-20T11:46:26.966Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.966Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:26.966Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:26.982Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:26.982Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:26.982Z daemon INFO time="2025-03-20T17:16:26+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:26.983Z daemon INFO Daemon is now listening on 127.0.0.1:57454
{"IP":"127.0.0.1","Port":"57454"}
2025-03-20T11:46:27.003Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.003Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.003Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.016Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.016Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.017Z daemon INFO Daemon is now listening on 127.0.0.1:57455
{"IP":"127.0.0.1","Port":"57455"}
2025-03-20T11:46:27.043Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.043Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.043Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.057Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.057Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.057Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.058Z daemon INFO Daemon is now listening on 127.0.0.1:57456
{"IP":"127.0.0.1","Port":"57456"}
2025-03-20T11:46:27.084Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.085Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.085Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.098Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.098Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.098Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.099Z daemon INFO Daemon is now listening on 127.0.0.1:57457
{"IP":"127.0.0.1","Port":"57457"}
2025-03-20T11:46:27.123Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.123Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.123Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.137Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.138Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.139Z daemon INFO Daemon is now listening on 127.0.0.1:57458
{"IP":"127.0.0.1","Port":"57458"}
2025-03-20T11:46:27.162Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.162Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.162Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.176Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.176Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.176Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.177Z daemon INFO Daemon is now listening on 127.0.0.1:57459
{"IP":"127.0.0.1","Port":"57459"}
2025-03-20T11:46:27.201Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.201Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.201Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.219Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.220Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.221Z daemon INFO Daemon is now listening on 127.0.0.1:57460
{"IP":"127.0.0.1","Port":"57460"}
2025-03-20T11:46:27.240Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.240Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.240Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.254Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.254Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.254Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.255Z daemon INFO Daemon is now listening on 127.0.0.1:57461
{"IP":"127.0.0.1","Port":"57461"}
2025-03-20T11:46:27.278Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.278Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.278Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.291Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.292Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.292Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.293Z daemon INFO Daemon is now listening on 127.0.0.1:57462
{"IP":"127.0.0.1","Port":"57462"}
2025-03-20T11:46:27.323Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.323Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.323Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.337Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.338Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.339Z daemon INFO Daemon is now listening on 127.0.0.1:57463
{"IP":"127.0.0.1","Port":"57463"}
Opening channel for service path '/services/electron-window'.
2025-03-20T11:46:27.369Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.369Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.369Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.386Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.387Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.387Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.389Z daemon INFO Daemon is now listening on 127.0.0.1:57464
{"IP":"127.0.0.1","Port":"57464"}
2025-03-20T11:46:27.417Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.417Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.417Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.431Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.431Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.431Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.432Z daemon INFO Daemon is now listening on 127.0.0.1:57465
{"IP":"127.0.0.1","Port":"57465"}
Opening channel for service path '/services/ide-updater'.
2025-03-20T11:46:27.453Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.453Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.454Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.468Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.469Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.469Z daemon INFO Daemon is now listening on 127.0.0.1:57466
{"IP":"127.0.0.1","Port":"57466"}
2025-03-20T11:46:27.492Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.492Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.493Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.510Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.511Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.511Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.512Z daemon INFO Daemon is now listening on 127.0.0.1:57468
{"IP":"127.0.0.1","Port":"57468"}
2025-03-20T11:46:27.535Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.535Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.535Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.551Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.552Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.553Z daemon INFO Daemon is now listening on 127.0.0.1:57469
{"IP":"127.0.0.1","Port":"57469"}
2025-03-20T11:46:27.607Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.607Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.607Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.614Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
Daemon is now listening on 127.0.0.1:57470
{"IP":"127.0.0.1","Port":"57470"}
2025-03-20T11:46:27.668Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.668Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.668Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.682Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.683Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.683Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.684Z daemon INFO Daemon is now listening on 127.0.0.1:57471
{"IP":"127.0.0.1","Port":"57471"}
2025-03-20T11:46:27.695Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 197.8 ms [Finished 2.393 s after frontend start]
2025-03-20T11:46:27.696Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-03-20T11:46:27.710Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.710Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.710Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.725Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.726Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.726Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.727Z daemon INFO Daemon is now listening on 127.0.0.1:57472
{"IP":"127.0.0.1","Port":"57472"}
2025-03-20T11:46:27.748Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.749Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.749Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.762Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.763Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.763Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.764Z daemon INFO Daemon is now listening on 127.0.0.1:57473
{"IP":"127.0.0.1","Port":"57473"}
2025-03-20T11:46:27.788Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.788Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.788Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.805Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.806Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.806Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.807Z daemon INFO Daemon is now listening on 127.0.0.1:57475
{"IP":"127.0.0.1","Port":"57475"}
2025-03-20T11:46:27.836Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.836Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.836Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.850Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.851Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.851Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.852Z daemon INFO Daemon is now listening on 127.0.0.1:57476
{"IP":"127.0.0.1","Port":"57476"}
2025-03-20T11:46:27.874Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.874Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.874Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.889Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.889Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.889Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.890Z daemon INFO Daemon is now listening on 127.0.0.1:57477
{"IP":"127.0.0.1","Port":"57477"}
2025-03-20T11:46:27.917Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.917Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.918Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.933Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.934Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.934Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.935Z daemon INFO Daemon is now listening on 127.0.0.1:57478
{"IP":"127.0.0.1","Port":"57478"}
2025-03-20T11:46:27.954Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.954Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.954Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:27.973Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:27.974Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:27.974Z daemon INFO time="2025-03-20T17:16:27+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:27.975Z daemon INFO Daemon is now listening on 127.0.0.1:57479
{"IP":"127.0.0.1","Port":"57479"}
2025-03-20T11:46:27.999Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.999Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:27.999Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.018Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.019Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.021Z daemon INFO Daemon is now listening on 127.0.0.1:57480
{"IP":"127.0.0.1","Port":"57480"}
2025-03-20T11:46:28.042Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.043Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.043Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.057Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.058Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.059Z daemon INFO Daemon is now listening on 127.0.0.1:57481
{"IP":"127.0.0.1","Port":"57481"}
2025-03-20T11:46:28.083Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.083Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.083Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.100Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.101Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.102Z daemon INFO Daemon is now listening on 127.0.0.1:57482
{"IP":"127.0.0.1","Port":"57482"}
2025-03-20T11:46:28.124Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.124Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.124Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.140Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.141Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.141Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.142Z daemon INFO Daemon is now listening on 127.0.0.1:57483
{"IP":"127.0.0.1","Port":"57483"}
2025-03-20T11:46:28.176Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.176Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.176Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.194Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.196Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.196Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.198Z daemon INFO Daemon is now listening on 127.0.0.1:57484
{"IP":"127.0.0.1","Port":"57484"}
2025-03-20T11:46:28.219Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.219Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.219Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.238Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.239Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.239Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.241Z daemon INFO Daemon is now listening on 127.0.0.1:57485
{"IP":"127.0.0.1","Port":"57485"}
2025-03-20T11:46:28.273Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.273Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.273Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.292Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.296Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.296Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.298Z daemon INFO Daemon is now listening on 127.0.0.1:57486
{"IP":"127.0.0.1","Port":"57486"}
2025-03-20T11:46:28.333Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.333Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.333Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.363Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.365Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.365Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.367Z daemon INFO Daemon is now listening on 127.0.0.1:57487
{"IP":"127.0.0.1","Port":"57487"}
2025-03-20T11:46:28.404Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.404Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.404Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.425Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.426Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.427Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.428Z daemon INFO Daemon is now listening on 127.0.0.1:57488
{"IP":"127.0.0.1","Port":"57488"}
2025-03-20T11:46:28.466Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.466Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.466Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.482Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.483Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.483Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.485Z daemon INFO Daemon is now listening on 127.0.0.1:57489
{"IP":"127.0.0.1","Port":"57489"}
2025-03-20T11:46:28.523Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.523Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.523Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.544Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.546Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.546Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.548Z daemon INFO Daemon is now listening on 127.0.0.1:57490
{"IP":"127.0.0.1","Port":"57490"}
2025-03-20T11:46:28.574Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.574Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.574Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.598Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.599Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.601Z daemon INFO Daemon is now listening on 127.0.0.1:57491
{"IP":"127.0.0.1","Port":"57491"}
2025-03-20T11:46:28.623Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.623Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.623Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.641Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.642Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.642Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.644Z daemon INFO Daemon is now listening on 127.0.0.1:57492
{"IP":"127.0.0.1","Port":"57492"}
2025-03-20T11:46:28.671Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.671Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.671Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.690Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.692Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.692Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.694Z daemon INFO Daemon is now listening on 127.0.0.1:57493
{"IP":"127.0.0.1","Port":"57493"}
2025-03-20T11:46:28.719Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.719Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.719Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.736Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.737Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.737Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.738Z daemon INFO Daemon is now listening on 127.0.0.1:57494
{"IP":"127.0.0.1","Port":"57494"}
2025-03-20T11:46:28.768Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.768Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.768Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.786Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.788Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.789Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.791Z daemon INFO Daemon is now listening on 127.0.0.1:57495
{"IP":"127.0.0.1","Port":"57495"}
2025-03-20T11:46:28.823Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.823Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.823Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.849Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.849Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.849Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.850Z daemon INFO Daemon is now listening on 127.0.0.1:57496
{"IP":"127.0.0.1","Port":"57496"}
2025-03-20T11:46:28.883Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.883Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.883Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.902Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.903Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.903Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:28.904Z daemon INFO Daemon is now listening on 127.0.0.1:57497
{"IP":"127.0.0.1","Port":"57497"}
2025-03-20T11:46:28.933Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.933Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:28.933Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:28.953Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:28.955Z daemon INFO time="2025-03-20T17:16:28+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:28.957Z daemon INFO Daemon is now listening on 127.0.0.1:57498
{"IP":"127.0.0.1","Port":"57498"}
2025-03-20T11:46:29.001Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.001Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.001Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.025Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.026Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.027Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:29.028Z daemon INFO Daemon is now listening on 127.0.0.1:57499
{"IP":"127.0.0.1","Port":"57499"}
2025-03-20T11:46:29.069Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.069Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.069Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.090Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.091Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.093Z daemon INFO Daemon is now listening on 127.0.0.1:57500
{"IP":"127.0.0.1","Port":"57500"}
2025-03-20T11:46:29.129Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.130Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.130Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.151Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.153Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.153Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:29.158Z daemon INFO Daemon is now listening on 127.0.0.1:57501
{"IP":"127.0.0.1","Port":"57501"}
2025-03-20T11:46:29.186Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.186Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
at Socket.<anonymous> (E:\Material\Arduino IDE\resources\app\lib\backend\main.js:2:44411)
at Socket.emit (node:events:514:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at Socket.push (node:internal/streams/readable:234:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2025-03-20T11:46:29.186Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.209Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.211Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.212Z daemon INFO Daemon is now listening on 127.0.0.1:57502
{"IP":"127.0.0.1","Port":"57502"}
2025-03-20T11:46:29.261Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.262Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.262Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.283Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.284Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.284Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:29.286Z daemon INFO Daemon is now listening on 127.0.0.1:57503
{"IP":"127.0.0.1","Port":"57503"}
2025-03-20T11:46:29.325Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.325Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.325Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.354Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.355Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.359Z daemon INFO Daemon is now listening on 127.0.0.1:57504
{"IP":"127.0.0.1","Port":"57504"}
2025-03-20T11:46:29.390Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.390Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.390Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.415Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.416Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.419Z daemon INFO Daemon is now listening on 127.0.0.1:57505
{"IP":"127.0.0.1","Port":"57505"}
2025-03-20T11:46:29.452Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.452Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.455Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.477Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.479Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.479Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:29.480Z daemon INFO Daemon is now listening on 127.0.0.1:57506
{"IP":"127.0.0.1","Port":"57506"}
2025-03-20T11:46:29.547Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.547Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.547Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.583Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.584Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.584Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Executing `arduino-cli daemon`"
2025-03-20T11:46:29.587Z daemon INFO Daemon is now listening on 127.0.0.1:57508
{"IP":"127.0.0.1","Port":"57508"}
2025-03-20T11:46:29.632Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.632Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.632Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.661Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.663Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.666Z daemon INFO Daemon is now listening on 127.0.0.1:57510
{"IP":"127.0.0.1","Port":"57510"}
2025-03-20T11:46:29.704Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.704Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.704Z daemon INFO Starting daemon from E:\Material\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-20T11:46:29.740Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="arduino-cli version 1.1.1"
2025-03-20T11:46:29.741Z daemon INFO time="2025-03-20T17:16:29+05:30" level=info msg="Using config file: c:\\Users\\hp\\.arduinoIDE\\arduino-cli.yaml"
2025-03-20T11:46:29.741Z daemon INFO Daemon is now listening on 127.0.0.1:57511
{"IP":"127.0.0.1","Port":"57511"}
2025-03-20T11:46:29.756Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2025-03-20T11:46:29.756Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
i have changed the download path
now my path is "E:\Material\Arduino IDE"
