Stell die IDE bitte so ein, das Du eine komplette Fehlermeldung bekommst.
Dann kopier die hier rein - ich kann nicht weiter raten.
Hier ist der komplette Fehlerlog:
Arduino: 1.8.19 (Linux), Board: "Arduino Uno"
arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/matze/.arduino15/packages -tools /usr/share/arduino/hardware/tools/avr -tools /home/matze/.arduino15/packages -libraries /home/matze/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path /tmp/arduino_build_733650 -warnings=none -build-cache /tmp/arduino_cache_75164 -prefs=build.warn_data_percentage=75 -verbose /home/matze/Arduino/Receive/Receive.ino
arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/matze/.arduino15/packages -tools /usr/share/arduino/hardware/tools/avr -tools /home/matze/.arduino15/packages -libraries /home/matze/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path /tmp/arduino_build_733650 -warnings=none -build-cache /tmp/arduino_cache_75164 -prefs=build.warn_data_percentage=75 -verbose /home/matze/Arduino/Receive/Receive.ino
Using board 'uno' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/arduino/avr
Detecting libraries used...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_733650/sketch/Receive.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_733650/sketch/Receive.ino.cpp" -o "/tmp/arduino_build_733650/preproc/ctags_target_for_gcc_minus_e.cpp"
/home/matze/Arduino/Receive/Receive.ino:59:27: schwerwiegender Fehler: configuration.h: Datei oder Verzeichnis nicht gefunden
Kompilierung beendet.
exit status 1
Fehler beim Kompilieren für das Board Arduino Uno.
Du hast irgendwas falsch gemacht.
Unter /usr/share wird nix angelegt.
Von daher eine Anleitung:
Die 1.8.19 downloaden.
Im Downloadordner dann rechte Maustaste auf das .tar.xz -> hier entpacken.
es entsteht ein Ordner arduino-1.8.19-linux64 (oder 32); da drin ein Ordner arduino-1.8.19
Den kopierst/verschiebst Du in Dein Userverzeichnis und benennst ihn in arduino-portable um.
Dann legst Du im Ordner arduino-portable einen neuen Ordner portable an.
Danach öffnest ein Terminalfenster
cd arduino-portable
./arduino
Es startet die IDE.
Jetzt kannst Du das Icon an der Favoritenleiste ankleben.
Gleichzeitig hat mit dem Start der IDE im Verzeichnis ~/arduino-portable ein Verzeichnis sketchbook und darunter ein Verzeichnis libraries Einzug gehalten.
Jetzt in -> DATEI - VOREINSTELLUNGEN die BoradverwalterURL eintragen und die Haken setzen für die Meldungen und die Ausgabe auf ALLE.
Dann holst Du Dir nacheinander erst die libs.
Die werden automatisch unter dem ~/arduino-portable/sketchbook/libraries einsortiert.
IDE beenden.
Dann
a) entpackst Du aus dem codearchiv den libraries-Ordner, bennenst den um und verschiebst ihn
oder b) kopierst aus den aus Deinem vorher angelegten ~/Arduino15/libraries
nach ~/arduino-portable/sketchbook/libraries
Dann die IDE wieder starten und den Sketch öffnen.
Die Meldung zum verschieben des Sketches bestätigen.
Der liegt jetzt unter ~/arduino-portable/sketchbook
Fertig.
Und den alten Arduino-Ordner einfach mittels uninstallskript wieder entfernen.
Das sollte es gewesen sein.
Ich habe jetzt alles 1:1 gemacht, leider meldet er immer noch Fehler
/home/matze/arduino-portable/arduino-builder -dump-prefs -logger=machine -hardware /home/matze/arduino-portable/hardware -hardware /home/matze/arduino-portable/portable/packages -tools /home/matze/arduino-portable/tools-builder -tools /home/matze/arduino-portable/hardware/tools/avr -tools /home/matze/arduino-portable/portable/packages -built-in-libraries /home/matze/arduino-portable/libraries -libraries /home/matze/arduino-portable/portable/sketchbook/libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path /tmp/arduino_build_55970 -warnings=none -build-cache /tmp/arduino_cache_358389 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/matze/arduino-portable/hardware/tools/avr -verbose /home/matze/arduino-portable/Receive/Receive.ino
/home/matze/arduino-portable/arduino-builder -compile -logger=machine -hardware /home/matze/arduino-portable/hardware -hardware /home/matze/arduino-portable/portable/packages -tools /home/matze/arduino-portable/tools-builder -tools /home/matze/arduino-portable/hardware/tools/avr -tools /home/matze/arduino-portable/portable/packages -built-in-libraries /home/matze/arduino-portable/libraries -libraries /home/matze/arduino-portable/portable/sketchbook/libraries -fqbn=arduino:avr:uno -ide-version=10819 -build-path /tmp/arduino_build_55970 -warnings=none -build-cache /tmp/arduino_cache_358389 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/matze/arduino-portable/hardware/tools/avr -verbose /home/matze/arduino-portable/Receive/Receive.ino
Using board 'uno' from platform in folder: /home/matze/arduino-portable/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/matze/arduino-portable/hardware/arduino/avr
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Alternatives for configuration.h: [tino_libs]
ResolveLibrary(configuration.h)
-> candidates: [tino_libs]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Alternatives for SoftwareWire.h: [SoftwareWire@1.6.0]
ResolveLibrary(SoftwareWire.h)
-> candidates: [SoftwareWire@1.6.0]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Alternatives for HTU21D_SoftwareWire.h: [HTU21D_SoftwareWire]
ResolveLibrary(HTU21D_SoftwareWire.h)
-> candidates: [HTU21D_SoftwareWire]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Alternatives for PinChangeInterrupt.h: [PinChangeInterrupt@1.2.9]
ResolveLibrary(PinChangeInterrupt.h)
-> candidates: [PinChangeInterrupt@1.2.9]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /dev/null
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs/CC1101.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs/RFM69.cpp
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs/calibrate.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs/codec.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs/datalinklayer.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire/SoftwareWire.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt0.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt1.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt2.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt3.cpp
Using cached library dependencies for file: /home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src/SPI.cpp
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /tmp/arduino_build_55970/preproc/ctags_target_for_gcc_minus_e.cpp
/home/matze/arduino-portable/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_55970/preproc/ctags_target_for_gcc_minus_e.cpp
Sketch wird kompiliert...
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/standard -I/home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_55970/sketch/Receive.ino.cpp -o /tmp/arduino_build_55970/sketch/Receive.ino.cpp.o
Compiling libraries...
Compiling library "tino_libs"
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/tino_libs/RFM69.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/tino_libs/calibrate.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/tino_libs/CC1101.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/tino_libs/datalinklayer.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/tino_libs/codec.cpp.o
Compiling library "EEPROM"
Compiling library "SoftwareWire"
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/SoftwareWire/SoftwareWire.cpp.o
Compiling library "HTU21D_SoftwareWire"
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp.o
Compiling library "PinChangeInterrupt"
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt0.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt2.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt1.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt3.cpp.o
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt.a
Compiling library "SPI"
Zuvor kompilierte Datei wird verwendet: /tmp/arduino_build_55970/libraries/SPI/SPI.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino_cache_358389/core/core_arduino_avr_uno_0d5fda4e030bd057188434b570b68c59.a
Linking everything together...
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_55970/Receive.ino.elf /tmp/arduino_build_55970/sketch/Receive.ino.cpp.o /tmp/arduino_build_55970/libraries/tino_libs/CC1101.cpp.o /tmp/arduino_build_55970/libraries/tino_libs/RFM69.cpp.o /tmp/arduino_build_55970/libraries/tino_libs/calibrate.cpp.o /tmp/arduino_build_55970/libraries/tino_libs/codec.cpp.o /tmp/arduino_build_55970/libraries/tino_libs/datalinklayer.cpp.o /tmp/arduino_build_55970/libraries/SoftwareWire/SoftwareWire.cpp.o /tmp/arduino_build_55970/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp.o /tmp/arduino_build_55970/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_55970/libraries/SPI/SPI.cpp.o /tmp/arduino_build_55970/../arduino_cache_358389/core/core_arduino_avr_uno_0d5fda4e030bd057188434b570b68c59.a -L/tmp/arduino_build_55970 -lm
/tmp/arduino_build_55970/libraries/tino_libs/RFM69.cpp.o (symbol from plugin): In function `RFM69::isr0()':
(.text+0x0): multiple definition of `GenericRadio::DATALEN'
/tmp/arduino_build_55970/libraries/tino_libs/CC1101.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `GenericRadio::RSSI'
(.text+0x0): multiple definition of `GenericRadio::FEI'
collect2: error: ld returned 1 exit status
Bibliothek tino_libs im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/tino_libs (legacy) wird verwendet
Bibliothek EEPROM in Version 2.0 im Ordner: /home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM wird verwendet
Bibliothek SoftwareWire in Version 1.6.0 im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire wird verwendet
Bibliothek HTU21D_SoftwareWire im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire (legacy) wird verwendet
Bibliothek PinChangeInterrupt in Version 1.2.9 im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: /home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI wird verwendet
exit status 1
OK, jetzt habe ich es ohne Fehler hinbekommen.
Also muss der Arduino-Ordner immer in mein Home-Verzeichnis sein?
Und darin enthalten mein libs in einen Unterordner?
Und muss der Unterordner im arduino-portable genau portable heißen?
Ja,
Nein.
Jein
Ja
Vielen dank, das Kompilieren klappt wunderbar.
Nur wenn ich den Sketch auf das Board bringe, kommt wieder eine Fehlermeldung.
Ich habe das ganze mal vor 2 Jahren gemacht, da hat das alles mal funktioniert.
Die Einstellungen habe ich so gemacht wie in der Doku beschrieben.
Ich habe einen FTDI Adapter dran hängen und "Arduino AS ISP" ausgewählt.
Jetzt wenn ich den Sketch rüber schieben will, dann kommt:
/home/matze/arduino-portable/arduino-builder -dump-prefs -logger=machine -hardware /home/matze/arduino-portable/hardware -hardware /home/matze/arduino-portable/portable/packages -tools /home/matze/arduino-portable/tools-builder -tools /home/matze/arduino-portable/hardware/tools/avr -tools /home/matze/arduino-portable/portable/packages -built-in-libraries /home/matze/arduino-portable/libraries -libraries /home/matze/arduino-portable/portable/sketchbook/libraries -fqbn=TiNo:avr:tino:cpu=1MHzatmega328IntBoot -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_472706 -warnings=none -build-cache /tmp/arduino_cache_353993 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/matze/arduino-portable/hardware/tools/avr -verbose /home/matze/arduino-portable/Receive/Receive.ino
/home/matze/arduino-portable/arduino-builder -compile -logger=machine -hardware /home/matze/arduino-portable/hardware -hardware /home/matze/arduino-portable/portable/packages -tools /home/matze/arduino-portable/tools-builder -tools /home/matze/arduino-portable/hardware/tools/avr -tools /home/matze/arduino-portable/portable/packages -built-in-libraries /home/matze/arduino-portable/libraries -libraries /home/matze/arduino-portable/portable/sketchbook/libraries -fqbn=TiNo:avr:tino:cpu=1MHzatmega328IntBoot -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_472706 -warnings=none -build-cache /tmp/arduino_cache_353993 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/matze/arduino-portable/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/matze/arduino-portable/hardware/tools/avr -verbose /home/matze/arduino-portable/Receive/Receive.ino
Using board 'tino' from platform in folder: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for configuration.h: [configuration]
-> candidates: [configuration]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for datalinklayer.h: [datalinklayer]
ResolveLibrary(datalinklayer.h)
-> candidates: [datalinklayer]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for GenericRadio.h: [GenericRadio]
ResolveLibrary(GenericRadio.h)
-> candidates: [GenericRadio]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for codec.h: [codec]
ResolveLibrary(codec.h)
-> candidates: [codec]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for RFM69.h: [RFM69]
ResolveLibrary(RFM69.h)
-> candidates: [RFM69]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for calibrate.h: [calibrate]
ResolveLibrary(calibrate.h)
-> candidates: [calibrate]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
Alternatives for HTU21D_SoftwareWire.h: [HTU21D_SoftwareWire HTU21D_SoftwareWire]
-> candidates: [HTU21D_SoftwareWire HTU21D_SoftwareWire]
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer/datalinklayer.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec/codec.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69/RFM69.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69/RFM69.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate/calibrate.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire/SoftwareWire.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt0.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt1.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt2.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt3.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src/SPI.cpp -o /dev/null
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /tmp/arduino_build_472706/preproc/ctags_target_for_gcc_minus_e.cpp
/home/matze/arduino-portable/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_472706/preproc/ctags_target_for_gcc_minus_e.cpp
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /tmp/arduino_build_472706/sketch/Receive.ino.cpp -o /tmp/arduino_build_472706/sketch/Receive.ino.cpp.o
Compiling library "configuration"
Compiling library "datalinklayer"
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer/datalinklayer.cpp -o /tmp/arduino_build_472706/libraries/datalinklayer/datalinklayer.cpp.o
Compiling library "GenericRadio"
Compiling library "codec"
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec/codec.cpp -o /tmp/arduino_build_472706/libraries/codec/codec.cpp.o
Compiling library "RFM69"
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69/RFM69.cpp -o /tmp/arduino_build_472706/libraries/RFM69/RFM69.cpp.o
Compiling library "calibrate"
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate/calibrate.cpp -o /tmp/arduino_build_472706/libraries/calibrate/calibrate.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire/SoftwareWire.cpp -o /tmp/arduino_build_472706/libraries/SoftwareWire/SoftwareWire.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp -o /tmp/arduino_build_472706/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt.cpp -o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt2.cpp -o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt2.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt0.cpp -o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt0.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt1.cpp -o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt1.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src/PinChangeInterrupt3.cpp -o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt3.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt0.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt1.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt2.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc-ar rcs /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt3.cpp.o
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=1000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR -I/home/matze/arduino-portable/hardware/arduino/avr/cores/arduino -I/home/matze/arduino-portable/hardware/arduino/avr/variants/eightanaloginputs -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM/src -I/home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate -I/home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire -I/home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt/src -I/home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src /home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI/src/SPI.cpp -o /tmp/arduino_build_472706/libraries/SPI/SPI.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino_cache_353993/core/core_TiNo_avr_tino_cpu_1MHzatmega328IntBoot_0d5fda4e030bd057188434b570b68c59.a
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_472706/Receive.ino.elf /tmp/arduino_build_472706/sketch/Receive.ino.cpp.o /tmp/arduino_build_472706/libraries/datalinklayer/datalinklayer.cpp.o /tmp/arduino_build_472706/libraries/codec/codec.cpp.o /tmp/arduino_build_472706/libraries/RFM69/RFM69.cpp.o /tmp/arduino_build_472706/libraries/calibrate/calibrate.cpp.o /tmp/arduino_build_472706/libraries/SoftwareWire/SoftwareWire.cpp.o /tmp/arduino_build_472706/libraries/HTU21D_SoftwareWire/HTU21D_SoftwareWire.cpp.o /tmp/arduino_build_472706/libraries/PinChangeInterrupt/PinChangeInterrupt.a /tmp/arduino_build_472706/libraries/SPI/SPI.cpp.o /tmp/arduino_build_472706/../arduino_cache_353993/core/core_TiNo_avr_tino_cpu_1MHzatmega328IntBoot_0d5fda4e030bd057188434b570b68c59.a -L/tmp/arduino_build_472706 -lm
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_472706/Receive.ino.elf /tmp/arduino_build_472706/Receive.ino.eep
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_472706/Receive.ino.elf /tmp/arduino_build_472706/Receive.ino.hex
Mehrere Bibliotheken wurden für "HTU21D_SoftwareWire.h" gefunden
Benutzt: /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire
Nicht benutzt: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/HTU21D_SoftwareWire
Bibliothek configuration im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/configuration (legacy) wird verwendet
Bibliothek datalinklayer im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/datalinklayer (legacy) wird verwendet
Bibliothek GenericRadio im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/GenericRadio (legacy) wird verwendet
Bibliothek codec im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/codec (legacy) wird verwendet
Bibliothek RFM69 im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/RFM69 (legacy) wird verwendet
Bibliothek EEPROM in Version 2.0 im Ordner: /home/matze/arduino-portable/hardware/arduino/avr/libraries/EEPROM wird verwendet
Bibliothek calibrate im Ordner: /home/matze/arduino-portable/portable/packages/TiNo/hardware/avr/3.0.2/libraries/calibrate (legacy) wird verwendet
Bibliothek SoftwareWire in Version 1.6.0 im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/SoftwareWire wird verwendet
Bibliothek HTU21D_SoftwareWire im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/HTU21D_SoftwareWire (legacy) wird verwendet
Bibliothek PinChangeInterrupt in Version 1.2.9 im Ordner: /home/matze/arduino-portable/portable/sketchbook/libraries/PinChangeInterrupt wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: /home/matze/arduino-portable/hardware/arduino/avr/libraries/SPI wird verwendet
/home/matze/arduino-portable/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_472706/Receive.ino.elf
Der Sketch verwendet 26400 Bytes (81%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 1089 Bytes (53%) des dynamischen Speichers, 959 Bytes für lokale Variablen verbleiben. Das Maximum sind 2048 Bytes.
/home/matze/arduino-portable/hardware/tools/avr/bin/avrdude -C/home/matze/arduino-portable/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b9600 -D -Uflash:w:/tmp/arduino_build_472706/Receive.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/matze/arduino-portable/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/matze/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 9600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x35
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x31
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x25
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7b
avrdude done. Thank you.
Beim Hochladen des Sketches ist ein Fehler aufgetreten
programmierst Du inSystem?
Sicher? Vermutlich nicht. Der FTDI-Adapter hängt am Controller, den Du programmieren willst...
WERKZEUGE - BOARD -> das richtige Board auswählen
WERKZEUGE - PORT -> den Port auf dem der FTDI klemmt auswählen (*)
SKETCH - HOCHLADEN (Oder STRG-U)
(*) Siehe Gerätemanager da muss der ohne gelbes Ausrufezeichen eingetragen sein.
WERKZEUGE - BOARD -> TiNo Boards
WERKZEUGE - PORT -> /dev/ttyUSB0
genau so habe ich das gemacht.
Das Fehlerbild sieht sehr nach falschem ComPort aus.
Bist Du sicher, dass das der FTDI ist? (Wenn Du den abziehst, muss der Port auch weg sein)
Ja wenn ich ihn abziehe ist der Port weg.
Irrelevant.
Vermutlich hast du vergessen DTR anzuschließen.
Das ist gut.
dann schaun wir mal, was da noch so geht...
Wenn Du das hochladen startest, kannst Du auch manuell in den Bootloader-Modus kommen.
Ist zu Anfang vielleicht etwas tricky, aber wenn Du es erstmal raus hast...
Mach Dir das schwarze Fenster unterm editor etwas größer..
Für den Test benutzt Du die Reset-Taste.
Die drückst Du einfach und hälst diese gedrückt.
Du startest das hochladen des Codes.
Nach dem kompilieren, kommt die Meldung des Starts der Übertragung: Jetzt lässt Du einfach die Resettatse los.
Wenn es nicht auf Anhieb klappt, kein Problem, einfach ein paar mal ausprobieren um rauszufinden, wann der günstigste Zeitpunkt zum loslassen der reset-taste ist ![]()
Irgendwann sollte das klappen. Und dann....
Am FTDI Adater ist keine Reset-Tastewenn ich richtig schaue.
Aber am Arduino, wo auch der Bootloader läuft.
Wenn es ein Arduino pro mini (ohne USB) ist, hat der auch einen Reset-Taster.
Ein nackter atmega328p aber schon mit Bootloader, hat jedenfalls einen Reset-Pin.
Es handelt sich um ein TiNo.
Auch der kann reset.
Wenn Du die Taste bestückt hast, kannst die mit Reset und GND verbinden.
Wenn nicht, tut es auch ein (Computer-)Jumper oder zur Not sogar ein Dupontkabel Female/Female.
Ich habe das jetzt mal x-mal versucht.
Aber es passiert immer das gleiche.
Overriding Baud Rate : 38400
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 8.0
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_879162/Receive.ino.hex"
avrdude: writing flash (26412 bytes):
Writing | ################################################## | 100% 10.32s
avrdude: 26412 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_879162/Receive.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_879162/Receive.ino.hex:
avrdude: input file /tmp/arduino_build_879162/Receive.ino.hex contains 26412 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 8.59s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x14 != 0x0c
avrdude: verification error; content mismatch
Der ausgewählte serielle Port
ist nicht vorhanden oder das Board ist nicht angeschlossen
Hast du schon das durchgelesen?
Hier noch was
