Arduino IDE: size(array) ends in error
Hi folks,
I have a simple question. How can I read out the length of an array for a "for loop"?
I would be very happyto get insight to it.
This works with C++ on VS2022 (console application)
#include <iostream>
std::string topics[5] = { "hellopl", "Testpl" };
int main()
    for (int i = 0; i < size(topics); i++) {
        std::cout << topics[i];
While this on Arduino IDE throws an error:
#include <iostream>
String topics[2]           = {"Hi", "test"};
    Serial.println(topics[i]);
error: 'size' was not declared in this scope
  109 |   for (int i = 0; i < size(topics); i++) {
Welcome to the forum
Do you want to know the size of the array in bytes or the number of elements in the array ?
String topics[2] = { "Hi", "test" };
    Serial.print("bytes used by the array = ");
    Serial.println(sizeof(topics));
    Serial.print("number of elements in the array = ");
    Serial.println(sizeof(topics) / sizeof(topics[0]));
try
for (int i = 0; i < sizeof(topics)/sizeof(String); i++)
Thanks for the quick answers!
The "possible" elements of an array. In my sample its "2" -> just for the loop of priting all defined topics in the array :slight_smile:
I assume that you mean the actual number of elements in the array as it will not change
you need the array identifier (a pointer to the start of the array in menory) and the type of elements, e.g.
  float data[] = { 1.5, 3.142, 9.6, 2.7, 1034.0 };
  for(int i = 0; i < sizeof(data) / sizeof(float); i++)
    Serial.println(data[i]);
prints
1.50
3.14
9.60
2.70
1034.00
Hmm. When I think about it, it might be the best to return the actual entries of the array instead of the possible, yes thats correct and agree with you
Not sure how that's possible since the function size() is indeed undeclared in your code.
Did you mean std::size()?
Or, you could use std:array which has a size() member function.
Both of these work on an ESP32 with the Arduino core:
#include <string>
  for (int i = 0; i < std::size(topics); i++) {
    Serial.println(topics[i].c_str());
void loop() {}
#include <string>
#include <array>
std::array<std::string, 5> topics = { "hellopl", "Testpl" };
  for (int i = 0; i < topics.size(); i++) {
void loop() {}
You can also use a for-each loop, which iterates through each element of an array.
  for (auto &i : topics) {
    Serial.println(i);
Note that both "size" functions above return the container's size (5) not the number of assigned elements (2). Will your container have a variable number of elements? If so, std::vector might be a better choice.
I used @horace solution, because this was indeed the solution I've looking for.
empty array's printing is not that usefull after all ^^
I would favour using
It does the same thing but will work with data of any type
