Arduino Ide stuck on uploading
The IDE complies successfully but fails on uploading.
I have checked everything.
  • The Right port is selected (COM7)
  • The Arduino is selected (Arduino UNO)
  • All the libraries are included and linked properly
  • Reinstalled the IDE ( Installed 3 previous versions of the IDE )
Here's the info:
IDE Version 2.3.2
The Code
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
#include <Servo.h>
Servo myservo;
int IR1 = 2;
int IR2 = 3;
int Slot = 4;           //Total number of parking Slots
int flag1 = 0;
int flag2 = 0;
    lcd.init(); //initialize the lcd
    lcd.backlight(); //open the backlight
pinMode(IR1, INPUT);
pinMode(IR2, INPUT);
myservo.attach(4);
myservo.write(100);
lcd.setCursor (0,0);
lcd.print("     ARDUINO    ");
lcd.setCursor (0,1);
lcd.print(" PARKING SYSTEM ");
delay (2000);
lcd.clear();
void loop(){
if(digitalRead (IR1) == LOW && flag1==0){
if(Slot>0){flag1=1;
if(flag2==0){myservo.write(0); Slot = Slot-1;}
}else{
lcd.print("    SORRY :(    ");
lcd.print("  Parking Full  ");
delay (3000);
lcd.clear();
if(digitalRead (IR2) == LOW && flag2==0){flag2=1;
if(flag1==0){myservo.write(0); Slot = Slot+1;}
if(flag1==1 && flag2==1){
delay (1000);
myservo.write(100);
flag1=0, flag2=0;
lcd.print("    WELCOME!    ");
lcd.print("Slot Left: ");
lcd.print(Slot);
Verbose Output
"C:\Users\hyper\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\hyper\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM7" -b115200 -D "-Uflash:w:C:\Users\hyper\AppData\Local\Temp\arduino\sketches\DF5B1149FFCDAE374B44518DC4561C67/Blink_copy_20240813191833.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\hyper\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\hyper\AppData\Local\Temp\arduino\sketches\DF5B1149FFCDAE374B44518DC4561C67/Blink_copy_20240813191833.ino.hex"
avrdude: writing flash (6058 bytes):
Writing | ##########################avrdude: stk500_recv(): programmer is not responding
Let me know if anything else is required.
Thanks :slight_smile: .
Hi @hypernova101. You described the Arduino board you are uploading to as "Uno". Something that can be confusing is there are multiple boards with "UNO" in their name. We need to be certain of exactly which one you have. The reason is that the problem might be caused by the IDE not being correctly configured for your specific board.
Please tell us which of the following boards you are attempting to upload to:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
