Thanks for replying. Sorry I guessed wrong.
The RTC code has two *.ino files and a README.md. That's all.
The sketch is just one of the built-in examples extended to output to a display as well as the serial port. I apologize for not stripping this down to a minimal example, but it's still pretty simple one you get past the verbose approach and preprocessor directives to support more than one display type.
Here is the first file, CBASS_ClockSetter.ino:
// It is useful to have the sketch confirm success or failure. This should always be visible on the Serial monitor, but
// also try to have it output on the most-used display types.
// Supported displays (do not edit without changing affected code):
#define LCD 1 // The original 2-line monochrome LCD
#define TFT 2 // TFT LCD, typically 320 x 240 color pixels.
#define NODISP 3
// The supported display to compile for at this time (edit as needed):
#define DISP TFT
#include <RTClib.h>
#if DISP == LCD
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield disp = Adafruit_RGBLCDShield();
#elif DISP == TFT
// Library for the Adafruit TFT LCD Display
#include <Adafruit_ILI9341.h>
#define TFT_CS 7
#define TFT_DC 6
Adafruit_ILI9341 disp = Adafruit_ILI9341(TFT_CS, TFT_DC); // The CS and DC pins.
#elif DISP == NODISP
#endif
RTC_DS1307 rtc; // This works with the DS3231 as well.
char daysOfTheWeek[7][12] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
int uploadLag = 8; // About how long it takes to upload the sketch and actually set the time, in seconds.
Serial.println("ClockSetter");
// If there is a physical display, start it and print a greeting there as well.
startAnyDisplay();
if (!rtc.begin()) {
// This code may not be what I thought. It returns true even if there is
// no RTC! The isrunning call will catch that case.
showText("Couldn't start RTC");
while (1);
if (!rtc.isrunning()) {
showText("Failed to communicate with RTC. Is one connected?");
while (1);
showText("Found RTC"); // New 2/8/19
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)) + TimeSpan(0, 0, 0, uploadLag));
Serial.print("Set RTC to ");
Serial.print(F(__DATE__)); Serial.print(" ");Serial.println(F(__TIME__));
Serial.println("Install another sketch now.");
Serial.println("Do not reset the Arduino with ClockSetter installed, or the time will be wrong.");
DateTime now, oldNow;
now = rtc.now();
// Reduce flickering by only displaying when the seconds digit has changed. Note that
// DateTime only has seconds.
if (now.second() != oldNow.second()) showTime(now);
oldNow = now;
delay(50); // Check again after 50 ms. Overkill, but too long a delay looks choppy.
and the second, Display.ino:
#if DISP == TFT
#define TFT_WIDTH 320
#define TFT_HEIGHT 240
#define TFT_LAND 3 // Rotation for normal text 1 = SPI pins at top, 3 = SPI at bottom.
#define TFT_PORT 2 // Rotation for y axis label, typically 1 less than TFT_LAND
#define LINEHEIGHT 19 // Pixel height of size 2 text is 14. Add 1 or more for legibility.
#define BLACK ILI9341_BLACK
#define WHITE ILI9341_WHITE
void startTFTDisplay() {
disp.begin();
disp.setRotation(TFT_LAND);
disp.fillScreen(BLACK);
// A start point for text size and color. If changed elsewhere, change it back.
disp.setTextSize(2); // A reasonable size. 1-3 (maybe more) are available.
disp.setTextColor(WHITE);
#endif
* Start the display type expected at compile time. It would be ideal to check for success and
* give a warning if needed, but these functions return void.
void startAnyDisplay() {
#if DISP == LCD
disp.begin(16, 2); // Start the library. Returns void
disp.setCursor(0, 0);
disp.print("ClockSetter LCD");
#elif DISP == TFT
startTFTDisplay();
// The TFT display is big enough to put this message at the bottom and still use
// top lines for other things.
disp.setTextSize(1);
disp.setCursor(0, TFT_HEIGHT - 2*LINEHEIGHT);
disp.print("Now install the CBASS sketch.");
disp.setCursor(0, TFT_HEIGHT - LINEHEIGHT);
disp.print("Do not restart ClockSetter.");
disp.print("ClockSetter TFT LCD");
startTFTDisplay();
Serial.println("No supported display is expected on the device.");
return;
#endif
Serial.println("If the intalled display matches compilation settings, you should see messages there.");
* This simply prints the given text on one line on the display. The complexity
* comes from the fact that different displays have different sizes, behaviors, and command names.
void showText(const char *t) {
// Always print to the serial monitor.
Serial.println(t);
#if DISP == NODISP
return;
#elif DISP == LCD
disp.setCursor(0, 1);
disp.print(t);
#elif DISP == TFT
// Determine the current display line and move to the start of the next, wrapping to the top
// if needed. This crudely assumes there are no headers or other special positions.
int16_t yNow = disp.getCursorY();
if (TFT_HEIGHT - yNow - LINEHEIGHT > 0) {
disp.setCursor(0, yNow + LINEHEIGHT);
disp.print(t);
#endif
/** Print the time to the display. For now this assumes that successive prints with no cursor change
* pick up from the most recent x location, but always at the same y (no automatic line feed).
* Place the time on a fixed text line, regardless of what else is on the screen. For LCD use the 2nd of 2 lines for time and the first
* for the date.
* For TFT use the 4th line for time and the 3rd for date.
* These are printed in reverse order because prompt time updates take priority over the date.
void showTime(const DateTime now) {
#if DISP == NODISP
return;
#elif DISP == LCD
disp.print(" ");
#elif DISP == TFT
disp.fillRect(0, 3*LINEHEIGHT, TFT_WIDTH, LINEHEIGHT, BLACK);
disp.setCursor(0, 3*LINEHEIGHT);
#endif
// Time
disp.print(now.hour());
disp.print(':');
if (now.minute() < 10) disp.print("0");
disp.print(now.minute());
disp.print(':');
if (now.second() < 10) disp.print("0");
disp.print(now.second());
disp.print(" ");
// Date
#if DISP == LCD
#elif DISP == TFT
disp.setCursor(0, 2*LINEHEIGHT);
disp.print(" ");
#endif
disp.print(daysOfTheWeek[now.dayOfTheWeek()]);
disp.print(", ");
disp.print(now.day());
disp.print('/');
disp.print(now.month());
disp.print('/');
disp.print(now.year());
