Arduino ide void loop
I want to order a car. Turn left while ctrt5000 Left(0) Center(0) Right(0) the first time. When you see Left(0) Center(0) Right(0) the second time, let the car move forward. How can I write code?
I use mega2560 ctrt500 L298N 3motor
Hello stranger
Post your sketch, well formated, with well-tempered comments and in so called
code tags "< code >" and schematic to see how we can help.
Please edit your post #3, select all code and click the <CODE> button to apply so-called code tags and next save your post. It makes it easier to read, easier to copy and the forum software will display it correctly.
It does not look like you have a problem with the IDE and hence your topic has been moved to a more suitable location on the forum.
@Mykuchp
What is your problem? Does the code compile? If not- please insert the error messages in the forum using the code tags.
I asked to edit, not to delete.
I've reported this topic as this is a cross post with Tcrt5000 L298N HCSR04 Servo
77 posts were merged into an existing topic: Is it possible to convert a .bin file to text ?
