error :
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:33:54: error: stray '\342' in program
analogWrite(m == LEFT ? enAPin : enBPin, speed < 0 ? −speed : speed );
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:33:55: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:33:56: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:1: error: stray '\342' in program
−128, −255, −128, 0};
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:2: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:3: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:9: error: stray '\342' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:10: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:11: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:17: error: stray '\342' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:18: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:43:19: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:30: error: stray '\342' in program
if (angleIndex == NUM ANGLES − 1) step = −1;
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:31: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:32: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:44: error: stray '\342' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:45: error: stray '\210' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:46: error: stray '\222' in program
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:151:10: error: stray '\342' in program
go(LEFT, −180);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:151:11: error: stray '\210' in program
go(LEFT, −180);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:151:12: error: stray '\222' in program
go(LEFT, −180);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:153:11: error: stray '\342' in program
go(RIGHT, −80);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:153:12: error: stray '\210' in program
go(RIGHT, −80);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:153:13: error: stray '\222' in program
go(RIGHT, −80);
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:73:13: error: 'ANGLES' was not declared in this scope
#define NUM ANGLES 7
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:75:27: note: in expansion of macro 'NUM'
unsigned char sensorAngle[NUM ANGLES] = { 60, 70, 80, 90, 100, 110, 120 };
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:73:20: error: expected ']' before numeric constant
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:77:24: note: in expansion of macro 'NUM'
unsigned int distance [NUM ANGLES];
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino: In function 'void readNextDistance()':
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:87:1: error: 'distance' was not declared in this scope
distance [angleIndex ] = readDistance ();
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:87:1: note: suggested alternative: 'readDistance'
readDistance
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:91:19: note: in expansion of macro 'NUM'
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:73:20: error: expected ')' before numeric constant
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:95:17: error: 'sensorAngle' was not declared in this scope
servo . write ( sensorAngle[angleIndex ] );
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino: In function 'void setup()':
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:129:17: error: 'sensorAngle' was not declared in this scope
servo . write ( sensorAngle[0] );
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:133:32: note: in expansion of macro 'NUM'
for (unsigned char i = 0 ; i < NUM ANGLES ; i ++)
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:73:20: error: expected ';' before numeric constant
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:133:36: error: expected ')' before 'ANGLES'
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:133:45: error: 'i' was not declared in this scope
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino: In function 'void loop()':
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:143:32: note: in expansion of macro 'NUM'
for (unsigned char i = 0 ; i < NUM ANGLES ; i++)
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:143:36: error: expected ')' before 'ANGLES'
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:143:45: error: 'i' was not declared in this scope
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:149:5: error: 'tooClose' was not declared in this scope
if (tooClose) {
C:\Users\priya\AppData\Local\Temp\.arduinoIDE-unsaved202505-15864-1g4uzil.j6khf\sketch_jan5d\sketch_jan5d.ino:149:5: note: suggested alternative: 'fclose'
if (tooClose) {
fclose
exit status 1
Compilation error: stray '\342' in program
