I'm using windows 10 and have come across an issue that has me stumped.
At some point in the last few years, I (or one of my kids) improperly uninstalled the Arduino IDE. I know this because when the application wouldn't open, I couldn't find the uninstall script. The error was (and still is) as shown in the attachment, "An error occurred while starting the application." "Access is denied". Followed by the ever helpful "OK" box. When you click OK, the application closes. I done a fair bit of searching on the internet for suggestions on how to solve this and have found nothing to date that works.
I have performed the following attempts at fixing the issue:
Basics:
- I'm running Windows 10
- My PC is in good working order
- I have used the IDE extensively in the past with no issues
- I'm signed in as Admin
- I'm using PC Matic for security
- I've been around PCs for as long as they have existed - so I have at least a little bit of experience :-).
What I've tried to date:
- I found and downloaded an arduino uninstall file, then ran the uninstall, downloaded the latest version of arduino IDE and installed it. When I tried to open the application, I got the same error.
- I rebooted the machine, and tried again to run the Arduino IDE and got the same error.
- I uninstalled the IDE and then re-installed it. I go the same error.
- I found some thread online that suggested I should clean up my registries. I uninstalled the IDE, then I downloaded and ran a program to clean out the old stuff laying around in my registries. I reinstalled the IDE and upon launching the application, I got the same error.
- I'm getting desperate now - So, I uninstalled the IDE and downloaded an older version, then installed it, and started the app. I got the same error.
- I've sunk about 5 hours into this at this point and decided that I should look for help - thus this post.
Any suggestions, guidance, opinions, or direction would be appreciated. I strongly suspect that there is something stuck in a directory or windows registry that I can't find... but that is pure speculation.
