Hello,
Can we interface and turn on leds or control equipment from ubuntu,java,php,html like languages ?
is it possible?
ritesh291991:
Hello,
is it possible?
Ubuntu is not a language.
But you can do it.
Plenty of examples if you had bothered to Google.
Did you study the Demo that is fixed at the top of this Section of the Forum?
...R
where is demo?
ritesh291991:
where is demo?
I told you in Reply #2
...R
will this java will work?
https://java.com/en/download/windows-64bit.jsp
ritesh291991:
What do you propose to do with it? Are you already a competent Java programmer?
Java is a program that runs on a PC. You can certainly write a PC program in Java that can communicate with an Arduino. Pretty much any PC programming language can do that. My demo uses Python and I suspect that will be easier than Java if you are a beginner.
...R
ok python is easier
yes i am begineer
please tell how should i make this pc communicate with internet and micro controller arduino.
Tell you again? Weren't the first two times sufficient? Why would we believe that the third time would be the charm?
I agree with @PaulS. It is time for you to do some of the work.
You still have not said whether you have studied my demo!
...R
hello,
robin2 i have studied your code how to run it in which software
ritesh291991:
hello,
I see a question mark but I don't know what your question is. You seem only to have made a statement.
Don't be afraid to write 5 or 6 lines of an explanation of what you want help with.
...R
IN WHICH SOFTWARE TO RUN PYTHON CODE?
ritesh291991:
What happened when you Googled "python"?
...R
ok what is advantages of python?
i have downloaded from here plaese tell how to run code it is not working?
ritesh291991:
https://www.python.org/i have downloaded from here plaese tell how to run code it is not working?
This is an Arduino Forum - not a Python Forum. I am not going to try to write a beginner's guide to Python. There are probably hundreds of them on the web already. There are also many books you could buy.
Compared to what?
...R
