Arduino IOT cloud disconnect doesn't release memory
I am trying to fix an issue with the IOT cloud where it disconnects, i Reconnect and each time I do available memory is lost until eventually the Nano 33 IOT crashes. I use the , false parameter in begin to prevent reboots but that results in out of memory crashes. Generally every time I reconnect to the cloud I lose 3.2k of memory. Maybe they're not closing a socket and hanging up the memory.
Here's some serial out from the sequence that shows losing memory on reconnect:
21:36:06.245 -> top of disco at minute:3
21:36:06.245 -> >>>> DISCONNECTED from network
21:36:06.245 -> Netstate = 0 FailState=1
21:36:08.629 -> Reconnect Retries=3
21:36:08.629 -> Now Free RAM = 10671
21:36:08.629 -> in disco at minute:3
21:36:16.495 -> Now Free RAM = 10671
21:36:16.495 -> top of disco at minute:3
21:36:16.495 -> >>>> DISCONNECTED from network
21:36:16.495 -> Netstate = 0 FailState=1
21:36:18.948 -> Reconnect Retries=4
21:36:18.948 -> Now Free RAM = 9555
21:36:18.948 -> in disco at minute:3
21:36:19.728 -> Connected to Arduino IoT Cloud
21:36:19.728 -> onNetworkConnect Connected
21:36:19.728 -> in reconn logText4=xxCommsFailp1xx
21:36:19.728 -> text msg=ALERT Reconnected to Cloud and logtxt=ALERT Reconnected to Cloud
21:36:19.728 ->
21:36:19.728 -> Starting connection to server...
21:36:21.539 -> connected to server
21:36:21.539 -> From=%2B14084098202&To=%2B14083983519&Body=ALERT Reconnected to Cloud
21:36:24.081 -> New DST:1
21:36:35.027 -> New Flow Set at minute:4
21:36:35.027 -> Got new Gpm1=0
21:36:35.027 -> Got new Gpm2=0
21:36:35.027 -> Got new Gpm3=0
21:36:35.027 -> before acloud update
21:36:35.027 -> Netstate = 1
21:36:36.031 -> * UPDATED
21:36:36.031 -> LOC : 21:35:39 Thu 23 Jun 2022
21:36:36.031 -> Now Free RAM = 6299
21:36:36.031 -> at minute:4
Here's my code that does this:
//String Version = "SysLogTextAlertsFlowsv8Test 6/15/2022";
Sketch generated by the Arduino IoT Cloud Thing
https://create.arduino.cc/cloud/things/ea8db7ae-93d0-4290-99a4-a026ac6aaccc
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
String logText;
2/20/2022
20220329 -- Use Serial1 on pins Tx,Rx tofr XBee
20220407 -- incorporated text alerts from the BTC
20220407 -- incorporated flow collection,time and dst flag and cloud update
20220423 -- Changed i'm alive to 24 hrs
20220517 -- added alert for reboots
20220606 -- added alerts for tank1 valve on/off
20220609 -- added ability to override T1Valve On/Off from webconsole
20220609 -- parameterized Twilio phone numbers
and added testsd flag = 1 if testing
20220613 -- removed v1open control and messages due to cloud instability
20220615 -- cleaned up messages to clarify connect vs reconnect
20220623 -- trying to fix reboot failure
#include "thingProperties.h"
#include <WiFiNINA.h>
#include <Arduino.h>
#include "wiring_private.h"
#include <pgmspace.h>
#include <SPI.h>
#include <Base64.h>
#include <NTPClient_Generic.h>
#include <NTPClient_Generic_Impl.h>
// GitHub - khoih-prog/NTPClient_Generic: Library for NTPClient to connect to an NTP time-server. Get time from a NTP time-server and keep it in sync. For ESP8266/ESP32, nRF52, SAMD21/SAMD51, STM32F/L/H/G/WB/MP1, Teensy, etc. besides AVR, using ESP WiFi, WiFiNINA, Ethernet W5x00, ENC28J60, LAN8742A, ESP8266/ESP32 AT-command WiFi.
#include <MemoryFree.h>;
#include <pgmStrToRAM.h>;
// test flags -- reset in prod
bool testsd = 1;
byte txtboth = 0; // flag to send texts to Colby and me or just me
byte status = WL_IDLE_STATUS;
volatile bool netstate = 0;
int retries = 0;
volatile int netFailState = 1;
byte t1empty = 0; // flag for tank state
byte pnum = 1;
String pnum1 = "4083983519";
String pnum2 = "5104147332";
String pnumtosendto = "4083983519"; // init to SD pnum
String TwilioNumRBC = "8059247990";
String TwilioNumSD = "4084098202";
String TwilioNum = "4084098202";
long ttime = 0;
const long TxtTimeDelay = 10000;
byte txtwait = 0;
int myfirst = 0;
bool NewT1V = 0;
bool OldT1Vopen = 0;
bool vfirst = 1;
bool reconn = 0;
String newlogtext;
bool newtext = 0;
bool txtfirst = 0;
bool cfirst = 1;
bool slrebooted = 0;
bool syncDone;
byte txt1 = 1;
byte txt2 = 2;
String Account_SID = SECRET_Acct_SID; // live acct
char toencode[] = SECRET_User_Auth; //live acct
int toencodeLength = 0;
int xencodedLength = 0; //Base64.encodedLength(toencodeLength);
//char encodedString[xencodedLength];
//Base64.encode(encodedString, toencode, toencodeLength - 1);
String astring = "Authorization: Basic ";
String authstring; // = astring + encodedString;
char server[] = "api.twilio.com"; // name address for twilio api (using DNS) https://api.twilio.com/2010-04-01
// Initialize the WiFiNINA client library
WiFiSSLClient txtclient;
WiFiServer myserver(80); // set up a server added
String ackstring = "xxackslogxxx";
/-----( Declare Constants and Pin Numbers )-----/
// "RXD" Nano Pin Rx on XBee pin 2 Tx
// "TXD" Nano Pin Tx on XBee pin 3 Rx
const int XRDelay = 3000; //time to wait after sending command to read
const int ReadDelay = 400; // time to wait to read buffer
String input = "";
String newmsg = "";
String CkInput = "";
int GotAck = 0;
int Tries = 0;
int maxtries = 10;
byte CkCommsOK = 1; // gets checked when transmitting commands
// I'm Alive timer sends a log message and text every alivetime
long atime = 0;
const long AliveTimeDelay = 86400000; // use 1 hour 3600000 in prod
byte alivewait = 0;
// flow collection
unsigned long Timer = 0;
unsigned long StartTime = 0;
unsigned long Interval = 60000; // 60 second interval to calc flow
int MinCnt=0;
volatile int Gpm1;
volatile int Gpm2;
volatile int Gpm3;
const int CountPin1 = 2; // the interrupt pin for count
const int CountPin2 = 3; // the interrupt pin for count
const int CountPin3 = 9; // the interrupt pin for count
IPAddress poolServerIP(129, 6, 15, 28); // time.nist.gov NTP server
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
NTPClient timeClient(Udp);
delay(3000);
Serial.println(Version);
// temp stuff to measure mem usage
Serial.print("Free RAM = ");
Serial.println(freeMemory());
// Serial.println();
pinMode(CountPin1,INPUT_PULLUP);
attachInterrupt (digitalPinToInterrupt(CountPin1), Counter1, FALLING) ; // start with int on pin 2 enabled and attached
pinMode(CountPin2,INPUT_PULLUP);
attachInterrupt (digitalPinToInterrupt(CountPin2), Counter2, FALLING) ; // start with int on pin 3 enabled and attached
pinMode(CountPin3,INPUT_PULLUP);
attachInterrupt (digitalPinToInterrupt(CountPin3), Counter3, FALLING) ; // start with int on pin 9 enabled and attached
initProperties();
// String Account_SID = SECRET_Acct_SID; // live acct
// char toencode[] = SECRET_User_Auth; //live acct
toencodeLength = sizeof(toencode);
xencodedLength = Base64.encodedLength(toencodeLength);
// String astring = "Authorization: Basic ";
authstring = astring + encodedString;
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
Serial.println("Connecting to: " + String(SSID));
WiFi.begin(SSID, PASS); delay(1000);
printWifiStatus();
// Connect to Arduino IoT Cloud
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::CONNECT, onNetworkConnect);
ArduinoCloud.addCallback(ArduinoIoTCloudEvent::DISCONNECT, onNetworkDisconnect);
// ArduinoCloud.addCallback(ArduinoIoTCloudEvent::SYNC, onIoTSync);
ArduinoCloud.begin(ArduinoIoTPreferredConnection, false);
// false disables the cloud timeout and reboot
// ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(DBG_INFO);
ArduinoCloud.printDebugInfo();
// ArduinoCloud.update();
if(netstate == 0) Serial.println("Netstate = 0");
if(netstate == 1) Serial.println("Netstate = 1");
timeClient.begin();
timeClient.setTimeOffset(-28800);
if(dST) timeClient.setTimeOffset(-25200);
Serial.println("Using NTP Server " + timeClient.getPoolServerName());
// Get XBee going
TwilioNum = TwilioNumRBC;
if(testsd == 1) TwilioNum = TwilioNumSD;
Serial1.begin(9600);
delay(XRDelay);
Serial1.print("Serial1 says hello!");
newmsg = "ALERT SysLog Restarting";
Serial.println("text msg=" + newmsg);
Sendtxt(txt1);
if (txtboth == 1 ) Sendtxt(txt2);
// t1Vopen = 0; // test var
} // ****************** end setup **********************************
// attempt to stay connected to WiFi
if (WiFi.status() != WL_CONNECTED) {
Serial.println("lost wifi connection");
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Connected to wifi");
printWifiStatus();
// Check for radio traffic
if ( Serial1.available() > 0 ){
delay(ReadDelay); // delay to get all of string
CkInput = Serial1.readString(); //Read from XBee
Serial.println( "in asynch logText1=" + logText );
logText = CkInput;
Serial.println( "in asynch logText2=" + logText );
// look for alert to send text
if (CkInput.indexOf("CommsFail") > 0 ) {
Serial1.flush();
Serial1.print("xxackxx");// send xxackxx
// delay(XRDelay);
// Serial1.print("xxackxx");
newmsg = "ALERT Comms Failure " +
CkInput.substring(CkInput.indexOf("CommsFail") + 9, CkInput.indexOf("CommsFail") + 11);
Sendtxt(txt1);
if (txtboth == 1 )Sendtxt(txt2);
if ((CkInput.indexOf("fvalveon") > 0 ) && txtwait == 0 ) {
CkInput = CkInput.substring(CkInput.indexOf("fvalveon") + 8);
//Serial.println("CkInput after strip leading xx="+CkInput);
if (CkInput.indexOf("x") >= 0) CkInput = CkInput.substring(0, CkInput.indexOf("x"));
//Serial.println("CkInput after strip trailing junk="+CkInput);
newmsg = "ALERT Watering on for Valve " + CkInput;
Sendtxt(txt1);
txtwait = 1;
if ((CkInput.indexOf("fvalveoff") > 0 ) && txtwait == 0) {
CkInput = CkInput.substring(CkInput.indexOf("fvalveoff") + 9);
newmsg = "ALERT Watering off for Valve " + CkInput;
Sendtxt(txt1);
txtwait = 1;
input = "";
if ((CkInput.indexOf("t1empalert") > 0 )) {
  t1empty = 1;
  newmsg = "ALERT Tank1 Empty";
  Sendtxt(txt1);
  txtwait = 1;
if ((CkInput.indexOf("t1fullalert") > 0 ) ) {
  t1empty = 0;
  newmsg = "ALERT Tank1 Full";
  Sendtxt(txt1);
  txtwait = 1;
if ((CkInput.indexOf("BTfull") > 0 ) && txtwait == 0 ) {
  if(t1empty == 0) newmsg = "ALERT Blending Tank Full - Pumps Off";
  else newmsg = "ALERT Blending Tank Full - P3 Off P1 On";
  Sendtxt(txt1);
  txtwait = 1;
if ((CkInput.indexOf("BTempty") > 0 ) && txtwait == 0 ) {
  newmsg = "ALERT Blending Tank Empty, Pumps On";
  Sendtxt(txt1);
  txtwait = 1;
if ((CkInput.indexOf("tvalveoff1") > 0 ) && txtwait == 0 ) {
  newmsg = "ALERT Tank1 Valve OFF";
  Sendtxt(txt1);
  txtwait = 1;
  t1Vopen = 0;
if ((CkInput.indexOf("tvalveon1") > 0 ) && txtwait == 0 ) {
  newmsg = "ALERT Tank1 Valve ON";
  Sendtxt(txt1);
  txtwait = 1;
  t1Vopen = 1;
if ((CkInput.indexOf("watpoff1") > 0 ) && txtwait == 0 ) {
  newmsg = "ALERT Pump1 Off";
  Sendtxt(txt1);
  txtwait = 1;
if (CkInput.indexOf("reboot") > 0 ) {
  Serial1.flush();
  delay(XRDelay);
newmsg = "ALERT Rebooted " +
CkInput.substring(CkInput.indexOf("reboot") + 6, CkInput.indexOf("reboot") + 8);
Sendtxt(txt1);
CkInput = "";
} // end serial available check for radio traffic
if (reconn == 1){
    reconn = 0;
// newlogtext = "onNetworkConnect Connected";
// logText = newlogtext;
t1Vopen = 1; // test var
Serial.println( "in reconn logText4=" + logText );
if( cfirst == 1){
cfirst =0;
newmsg = "ALERT Connected to Cloud " ;
newlogtext = newmsg;
Serial.println("text msg=" + newmsg + " and logtxt=" + logText);
Sendtxt(txt1);
else {
newmsg = "ALERT Reconnected to Cloud " ;
//Serial.println("text msg=" + newmsg);
Sendtxt(txt1);
/* check for new T1VOpen signal and send alert and command
if(NewT1V == 1 ){
NewT1V=0;
if (vfirst == 1 || reconn == 1){
vfirst = 0; reconn = 0;
Sendtxt(txt1);
else{
if(OldT1Vopen != t1Vopen){
if (t1Vopen == 1){
GotAck = 0; Tries = 0; input = ""; //setup for next xmit
while (GotAck==0 && Tries < maxtries) { // send redundant stop signal
Serial1.print("xxT1ValveOVONxx");
Serial.println("xxT1ValveOVONxx");
delay(XRDelay) ; // delay to allow time to respond was 2000
GetAck();
if(GotAck == 1 ){
newmsg = "ALERT Overriding Tank1 Valve ON";
Sendtxt(txt1);
txtwait = 1;
OldT1Vopen = 1;
logText= "xxT1ValveOVONxx";
else {
Serial.print("No ack in tries=");
Serial.println(Tries);
if (Tries==maxtries){
Serial1.print("syCommsFailIC"); // Send out failure notice
Serial.println("IC Com Fail"); // Send out failure notice
else {
Serial1.print("xxT1ValveOVOFFxx");
Serial.println("xxT1ValveOVOFFxx");
GetAck();
if(GotAck == 1 ){
newmsg = "ALERT Overriding Tank1 Valve OFF";
Sendtxt(txt1);
txtwait = 1;
OldT1Vopen = 0;
logText= "xxT1ValveOVOFFxx";
else {
Timer = millis();
if (Timer - StartTime >= Interval) {
StartTime = millis(); // reset Start to now for next get request
MinCnt += 1; //count minutes since starting
myMinute=MinCnt;
  Serial.println("New Flow Set at minute:" + String(MinCnt));
  galPerMin1 = Gpm1;
  Serial.println("Got new Gpm1="+String(galPerMin1));
  galPerMin2 = Gpm2;
  Serial.println("Got new Gpm2="+String(galPerMin2));
  galPerMin3 = Gpm3;
  Serial.println("Got new Gpm3="+String(galPerMin3));
  Gpm1=0;
  Gpm2=0;
  Gpm3=0;
  Serial.println("before acloud update");
timeClient.update();
if (timeClient.updated())
Serial.println("* UPDATED");
Serial.println("* NOT UPDATED");
Serial.println("LOC : " + timeClient.getFormattedDateTime());
timeDate = timeClient.getFormattedDateTime();
// show mem every interval
Serial.print("Now Free RAM = ");
Serial.println("at minute:" + String(myMinute));
if(netstate ==0){
Serial.print(F("Now Free RAM = "));
Serial.print(F("top of disco at minute:"));
Serial.println (String(myMinute));
Serial.println(F(">>>> DISCONNECTED from network"));
Serial.println("Netstate = 0 FailState="+String(netFailState));
// ArduinoCloud.update(); // try to reconnect
delay(2000);
retries += 1;
Serial.print(F("Reconnect Retries="));
Serial.println ( String(retries));
Serial.print(F("in disco at minute:"));
Serial.println( String(myMinute));
if(retries == 10 && netstate ==0)reboot();
if(freeMemory()< 4000) reboot();
// delay(1000);
// Delay TxtTimeDelay after sending text alerts to prevent multiples
if (txtwait == 1) // this section waits for a while then reenables on/off
if ( ttime == 0 ) ttime = millis();
if ( millis() - ttime < 0 ) ttime = 0 ; // make sure you aren't waiting over a millis
// reached max reset which should be exceedingly rare but possible
if ( millis() - ttime > TxtTimeDelay )
ttime = 0 ;
txtwait = 0 ;
if (slrebooted == 1 ) {
newmsg = "Notice - SysLog Rebooted";
logText = newmsg;
Sendtxt(txt1);
slrebooted = 0;
// Delay AliveTimeDelay after sending alive alerts
// this section waits for a while then reenables alive messages
if (alivewait == 1)
if ( atime == 0 ) atime = millis();
if ( millis() - atime < 0 ) atime = 0 ; // make sure you aren't waiting over a millis
if ( millis() - atime > AliveTimeDelay )
atime = 0 ;
alivewait = 0 ;
if (myfirst == 0 ) {
Serial.println(F("Waiting for TXT Server Response"));
Serial.print(F("status = "));
Serial.println(txtclient.status());
myfirst = 1;
while (txtclient.available()) {
char c = txtclient.read();
// Serial.write(c); // write twilio response if needed otherwise just empty buffer
txtclient.flush();
txtclient.stop();
// get actual changed text and send it
if(newtext == 1 ) {
newtext = 0;
if (txtfirst == 1){
txtfirst = 0;
else {Serial.println("Got new text="+newlogtext);
newmsg = "ALERT Got new text="+newlogtext;
Serial1.print("Got new text="+newlogtext);
Sendtxt(txt1);
txtwait = 1;
newlogtext="";
} // end loop *************
void reboot() {
Serial.println("Rebooting...");
NVIC_SystemReset();
slrebooted = 1;
void onLogTextChange() {
newtext = 1;
newlogtext = logText;
logText = "got input message=" + newlogtext; // Add your code here to act upon LogText change
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void onNetworkConnect() {
Serial.println("onNetworkConnect Connected");
// logText = "onNetworkConnect Connected";
netstate = 1;
reconn = 1; txtfirst = 1; retries = 0;
void onNetworkDisconnect() {
netstate = 0;
Serial.println("onNetworkDisconnect Disconnected");
//void onIoTSync() {
// syncDone = 1;
// Serial.println("Arduino synced to IoT Cloud");
// RBC P# 8059247990 SD P# 4084098202
void Sendtxt(byte &pnum) {
if (pnum == 1) pnumtosendto = pnum1;
if (pnum == 2) pnumtosendto = pnum2;
/* String Account_SID = SECRET_Acct_SID; // live acct
int toencodeLength = sizeof(toencode);
int xencodedLength = Base64.encodedLength(toencodeLength);
String authstring = astring + encodedString; */
String body = "From=%2B1" + TwilioNum + "&To=%2B1" + pnumtosendto + "&Body=" + newmsg; // added
int bodylen = body.length();
Serial.println("\nStarting connection to server...");
if (txtclient.connectSSL(server, 443)) {
Serial.println("connected to server");
// Make a Twilio api request
String(TWPOST) = "POST /2010-04-01/Accounts/" + Account_SID + "/Messages HTTP/1.1\r\n"
+ authstring + "\r\n"
+ "Host: api.twilio.com\r\n"
+ "Cache-control: no-cache\r\n"
+ "User-Agent: Arduino/1.0\r\n"
+ "Content-Type: application/x-www-form-urlencoded\r\n"
+ "Content-Length: " + bodylen + "\r\n"
+ "Connection: close\r\n"
+ "\r\n"
+ body
+ "\r\n";
// txtclient.println(TWPOST); //temporarily don't post
// Serial.println(TWPOST); // full post for inspection temporarily
Serial.println(body);
else {
Serial.println("twilio connection failed");
txtclient.flush();
txtclient.stop();
void Counter1() // counts pulses from flow meter 1
Gpm1 += 1;
// Serial.println("got interrupt1");
void Counter2() // counts pulses from flow meter 2
Gpm2 += 1;
//Serial.println("got interrupt2");
void Counter3() // counts pulses from flow meter 3
Gpm3 += 1;
// Serial.println("got interrupt3");
void onTimeDateChange() {
// Add your code here to act upon TimeDate change
void onDSTChange() {
Serial.println("New DST:" + String(dST));
//void onT1VopenChange() {
// Serial.println("New T1Vopen:" + String(t1Vopen));
// OldT1Vopen = !t1Vopen;
// NewT1V=1;
void GetAck(){
if(Serial1.available() > 1 && Tries < maxtries) { //Read from XBee
delay(ReadDelay); // delay 0.1 sec to get all of string
String input = Serial1.readString(); //Read from XBee
if (input.indexOf("relay") >= 0 ) {
GotAck = 1; //received ack
CkCommsOK = 1;
CkInput = input;
Serial.print("Got ack in tries=");
Serial.println(String(Tries) + " CkInput=" + CkInput);
else {
if (Tries == maxtries-1){
Serial.println("Com Fail"); // Send out failure notice
CkCommsOK = 0;
++Tries;
input="";
I suspect that someone knows this which is why they have the watchdog timer in the first place. Would be nice if this was fixed.
So I finally figured out what I was doing wrong. I was calling begin
(ArduinoCloud.begin(ArduinoIoTPreferredConnection) ) multiple times trying to reconnect. Actually all you need to do is just allow cloud update ( ArduinoCloud.update(); ) at top of loop to execute and it reconnects without losing memory. My bad. Don't know why no one commented on my post. Maybe code too long to look at.
Anyway SOLVED.
