I'm using an Arduino R4 Wi-Fi with a DS18B20 temperature sensor. I've created an Arduino IoT Cloud project and I'm having problems with my cloud variable not updating or syncing to the cloud. I know that the sensor is working and is reading the correct temperature as I also have an I2C LCD screen on my project and the temperature readout is accurate. I can also see that the IoT cloud is receiving data from my device 'live', just that the floating point number is also showing as zero and not updating.
Has anyone any ideas to solve this?
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SD.h>
#include "thingProperties.h" // Include Arduino IoT Cloud Thing properties
#include <Arduino_ConnectionHandler.h>
const int SENSOR_PIN = 13; // Arduino pin connected to DS18B20 sensor's DQ pin
OneWire oneWire(SENSOR_PIN); // setup a oneWire instance
DallasTemperature tempSensor(&oneWire); // pass oneWire to DallasTemperature library
LiquidCrystal_I2C lcd(0x3F, 16, 2); // I2C address 0x3F (from DIYables LCD), 16 column and 2 rows
float tempCelsius; // temperature in Celsius (floating-point)
Serial.begin(9600); // initialize serial
delay(1500);
// Connect to WiFi
Serial.println("Attempting to connect to WiFi...");
while (!WiFi.begin(SECRET_SSID, SECRET_OPTIONAL_PASS)) {
Serial.println("Failed to connect to WiFi. Retrying...");
// Wait for WiFi connection to be established
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi!");
// Initialize Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
// Defined in thingProperties.h
initProperties();
tempSensor.begin(); // initialize the sensor
lcd.init(); // initialize the lcd
lcd.backlight(); // open the backlight
tempSensor.requestTemperatures(); // send the command to get temperatures
tempCelsius = tempSensor.getTempCByIndex(0); // read temperature in Celsius
Serial.print(tempCelsius); // print the temperature in Celsius
Serial.println("°C");
lcd.clear();
lcd.setCursor(0, 0); // start to print at the first row
lcd.print("CONCRETE TEMP:"); // print concrete temp wording
lcd.setCursor(0, 1); // start to print at the second row
lcd.print(tempCelsius); // print the temperature in Celsius
lcd.print((char)223); // print ° character
lcd.print("C");
ArduinoCloud.update(); // Update Arduino IoT Cloud
delay(10000); // read temperature once every 15 minutes which is 900000 ms
// Function called when Concrete_Temperature property changes
void on_Concrete_Temperature_change() {
// You can add custom behavior here if needed
#include <SD.h>
delay(1500);
// Connect to WiFi
Maximum is 4
initProperties();
lcd.clear();
lcd.print("C");
Select the "IoT_Concrete_Temperature" tab and delete this line of code:
The Arduino Cloud Thing sketch generation system automatically adds a declaration of the tempCelsius variable to the thingProperties.h file of the sketch so you don't need one in the IoT_Concrete_Temperature.ino file.
Thank you! I've managed to get some data into my IoT dashboard for the first time! I'm very pleased
Quick question, are you familiar with issues with devices dropping offline for a bit and then coming back online? Any recommendations here? As you can see from the images below there was an outage for around 10 minutes.
My area of knowledge is limited to the user interface of Arduino Cloud and sketch code. I don't have any involvement in or knowledge of the Arduino Cloud server infrastructure or even much about network communication in general.
I recommend leaving the UNO R4 WiFi board connected to your computer with a USB cable and running a serial terminal program. The Thing sketch will print some logs about the status of connectivity to the Wi-Fi access point as well as to the Arduino Cloud servers.
The logging behavior is controlled by this line of your Thing sketch:
The default level 2 is reasonable to get started on the investigation but you can increase the level in order to get more detailed information about the problem.
The obvious serial terminal to use is the Serial Monitor feature of Arduino Cloud. However, it is not really suitable for logging data over the course of days, as might be necessary if the outages don't occur frequently. In this case it would be best to use a standalone terminal. I can recommend the free open source PuTTY terminal:
You can configure PuTTY to write the logs to a file, which could make it easier to review them later.
I prefer PuTTY due to the fact that it is cross-platform (meaning I can use the same tool regardless of whether the computer is running Linux, macOS, or Windows), but if for some reason it isn't to your liking then there are definitely some other excellent free serial terminal programs available for whichever operating system you use.
This is because delay is (expectingly) blocking the loop(), and the result is that after a few seconds of inactivity the Cloud considers that board as disconnected.
You should use a different approach using millis() instead of delay()
Basically something like this (warning: not tested):
