Arduino IoT won't connect to my network
The "Arduino IoT Cloud" does not recognize my internet connection, I attach an image where it shows the message that the connection was failed. I have entered my network credentials correctly and successfully added the secret key, even disabled my antivirus.
Any suggestion what to do?
EV0
  1. Ensure that your credentials are correct and remember that both SSID and password are case sensitative.
  2. The Arduino IoT Cloud uses the following domains and ports, which need to be whitelisted in your firewall.
Domain Port
mqtts-up.iot.arduino.cc 8884
mqtts-sa.iot.arduino.cc 8883
wss.iot.arduino.cc 8443
You will also need to allow NTP access on port 123 UDP for time.arduino.cc.
  1. If the above doesn't reslove the issue please try the following steps: If your device can't be added or won't connect to IoT Cloud
