Uno R4 WiFi not connecting to iot.arduino.cc
Hello all,
Just started with Arduino and facing connectivity problems.
Obviously this problem has popped up frequently in forum discussions but so far I have not been able to solve the problem.
Here is an example of Serial Monitor messages:
***** Arduino IoT Cloud - 2.3.1 *****
Device ID: 9d1cd65b-f876-4ef5-af5f-79c9fe7a7970
MQTT Broker: iot.arduino.cc:8885
WiFi.status(): 0
Current WiFi Firmware: 0.4.1
Connected to "Himmelriiki-2G"
TimeServiceClass::getRemoteTime cannot get time from NTP, fallback on connection handler
TimeServiceClass::getRemoteTime cannot get time from connection handler
ArduinoIoTCloudTCP::handle_SyncTime could not get valid time. Retrying now.
ArduinoIoTCloudTCP::handle_ConnectMqttBroker could not connect to iot.arduino.cc:8885 Error: -2
...and so it goes on indefinitely.
I have uninstalled and reinstalled every component, the Uno firmware is the latest version. I checked the firewall settings (Windows 11) and can't find anything. The SSID password etc. is correct.
I am running out of options. What should I try next?
Hi, can you check if the solution in the post below fixes your issues?
