Now posted like you are asked to in "How to use the forum"
//Ultrasone
#include <NewPing.h>
int trigPin = 3;
int echoPin = 5;
NewPing sonar(trigPin, echoPin, 500);
//Servo
#include <Servo.h>
Servo ServoMoter;
int servo = 6;
int valServo;
//Lcd
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 10, d5 = 9, d6 = 8, d7 = 7;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//This shit
#include <EEPROM.h>
//Rotary Enconder
int rotaryA = 2;
int rotaryB = 4;
long rotaryCount = 1;
long lastRotaryCount = 0;
//Leds
int ledarray[] = {A2, A3, A4, A5, A6, A7};
//Button
#define Button A1
//Variables
int ButtonState;
int lastButtonState;
int state = 0;
boolean Flag = false;
int Hoek;
int test;
int test2;
//Menu opties
char *MainMenu[] = {" Afstand Meten",
">Afstand Meten",
" Hoek Meten",
">Hoek Meten",};
char *AfstandMeten[] = {">Minimum meetwaarde instellen",
">Maximum meetwaarde instellen",
">Bekijken verdeling over leds",
">Meten activeren",
">Terug naar hoofdmenu",
" Minimum meetwaarde instellen",
" Maximum meetwaarde instellen",
" Bekijken verdeling over leds",
" Meten activeren",
" Terug naar hoofdmenu"
char * HoekMeten[] = {">Instellen Van De Hoek",
">Hoek Activeren",
">Terug Naar Hoofdmenu",
" Instellen Van De Hoek",
" Hoek Activeren",
" Terug Naar Hoofdmenu"};
//lcd
lcd.begin(16, 2);
//button
pinMode(Button, INPUT);
//rotary
pinMode(rotaryA, INPUT);
pinMode(rotaryB, INPUT);
//Leds
for (int i = 0; i<6;i++){
pinMode(ledarray[i], OUTPUT);
//Servo
ServoMoter.attach(servo);
attachInterrupt (0, rotaryTurn, RISING);
lcd.setCursor(0,0);
if(rotaryCount >2 && state == 0){
rotaryCount = 1;
if(rotaryCount <1 && state == 0){
rotaryCount = 2;
if (rotaryCount >3 && state == 1){
rotaryCount = 1;
if (rotaryCount <1 && state == 1){
rotaryCount = 3;
if (rotaryCount >180 && state == 2){
rotaryCount = 1;
if (rotaryCount <1 && state == 2){
rotaryCount = 180;
if (rotaryCount <1 && state == 4){
rotaryCount = 5;
if (rotaryCount >5 && state == 4){
rotaryCount = 1;
switch (state)
case 0:
mainMenu(rotaryCount);
case 1:
analogWrite(ledarray[0], 0);
SubHoekMeten(rotaryCount);
case 2:
Sub1Instellen_Van_Hoek(rotaryCount);
case 3:
Sub1Activeren_Van_Hoek(rotaryCount, Hoek, ServoMoter);
case 4:
SubAfstandMeten(rotaryCount);
analogWrite(ledarray[0], 1023);
if (lastRotaryCount != rotaryCount) {
lastRotaryCount = rotaryCount;
void rotaryTurn(){
if (digitalRead (rotaryB)) {
rotaryCount--;
Flag = false;
else {
rotaryCount++;
Flag = false;
void mainMenu(int aantalMenuOpties){
ButtonState = analogRead(Button);
if( aantalMenuOpties == 1){
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(MainMenu[1]);
lcd.setCursor(0,1);
lcd.print(MainMenu[2]);
if( aantalMenuOpties == 2){
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(MainMenu[0]);
lcd.setCursor(0,1);
lcd.print(MainMenu[3]);
if (aantalMenuOpties == 2 && ButtonState <10 && state == 0){
rotaryCount = 1;
state = 1;
if (aantalMenuOpties == 1 && ButtonState <10 && state == 0){
rotaryCount = 1;
state = 4;
void SubAfstandMeten(int aantalMenuOpties){
switch (aantalMenuOpties)
case 1:
if (Flag == false){
Flag = true;
lcd.clear();}
lcd.setCursor(0,0);
lcd.print(AfstandMeten[0]);
lcd.setCursor(0,1);
lcd.print(AfstandMeten[6]);
case 2:
if (Flag == false){
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(AfstandMeten[1]);
lcd.setCursor(0,1);
lcd.print(AfstandMeten[7]);
case 3:
if (Flag == false){
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(AfstandMeten[2]);
lcd.setCursor(0,1);
lcd.print(AfstandMeten[8]);
case 4:
if (Flag == false){
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(AfstandMeten[3]);
lcd.setCursor(0,1);
lcd.print(AfstandMeten[9]);
case 5:
if (Flag == false){
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(AfstandMeten[4]);
/* if ( aantalMenuOpties == 1 && ButtonState < 10){
Flag = false;
state = 5;
if ( aantalMenuOpties == 2 && ButtonState < 10){
Flag = false;
state = 6;
if ( aantalMenuOpties == 3 && ButtonState < 10){
Flag = false;
state = 7;
if ( aantalMenuOpties == 4 && ButtonState < 10){
Flag = false;
state = 4;
if ( aantalMenuOpties == 5 && ButtonState < 10){
Flag = false;
state = 0;
void SubHoekMeten(int aantalMenuOpties){
if (ButtonState >50){
test = 1;
case 1:
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(HoekMeten[0]);
lcd.setCursor(0,1);
lcd.print(HoekMeten[4]);
case 2:
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(HoekMeten[1]);
lcd.setCursor(0,1);
lcd.print(HoekMeten[5]);
case 3:
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(HoekMeten[2]);
if ( aantalMenuOpties == 1 && ButtonState < 10 && test == 1){
Flag = false;
state = 2;
Flag = false;
state = 3;
Flag = false;
state = 0;
void Sub1Instellen_Van_Hoek(int aantalMenuOpties){
test2 =1;
if (Flag == false)
Flag = true;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Aantal Graden:");
lcd.setCursor(0, 1);
lcd.print(rotaryCount);
if (test2 == 1){
if (ButtonState < 10 && state == 2){
Hoek = rotaryCount;
state = 1;
test=0;
test2 = 0;
void Sub1Activeren_Van_Hoek(int aantalMenuOpties, int graden, Servo motor){
motor.write(graden);
state = 1;
First thing I notice is the indentation that's all over the place. Makes it very hard to read.
But I don't see a delay, which is good. But what you all want to do is very hard to read. To tackle this problem alone, make a MCVE.
PS:
Watch variable type. Is 'trigPin' ever going to be -30000? Aka, byte will do. Applies to almost all variables.
PPS:
Analog in is just an extra task for A pins. And they don't do PWM (analogWrite()). But the IDE does map analogWrite() to digital pins (HIGH for >512, LOW otherwise).
// is the same as
digitalWrite(ledarray[0], LOW);
// is the same as
digitalWrite(ledarray[0], HIGH);
PPPS:
Try to stick to a single name scheme. NowyouWrite_like_it. Common is cammelCaseForVariables (and functions), UpperCammelCaseForConstants (and classes).
PPPPS:
Try to use self explaining variable names. For example:
'Flag' => what does it flag?
'ledarray' => 'LedPins' (plural to indicate an array)
'test' => test what?
etc
