I know this is probably all over this website, but every one I've read so far doesn't seem to help me fix my problem. I am brand new to this and while I think my code is good I can't seem to get it to upload to my Leonardo. I have verified the drivers are correct, I have switched ports. I have swapped out Micro USB cables. I've reset it and my PC and the software countless times. Here is the error message. I hope someone can help.
Sketch uses 5246 bytes (18%) of program storage space. Maximum is 28672 bytes.
Global variables use 302 bytes (11%) of dynamic memory, leaving 2258 bytes for local variables. Maximum is 2560 bytes.
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2047)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM7'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM7; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
