I am using an Arduino leonardo to make a usb handbrake with a 10k potentiometer whenever i upload the code to the leonardo it says that Joystick was not declared in this scope i am following a tutorial that i have linked below and here is the code itself
#include <Joystick.h>
{pinMode(A0, INPUT);
Joystick.begin();}
const int pinToButtonMap = A0;
{int pot = analogRead(A0);
int mapped = map(pot,0,1023,0,255);
{Joystick.setThrottle(mapped);}}
does anybody have any ideas what to do so this program works for me you will be a lifesaver
If you grabbed the "joystick" library from the Library Manager you got the wrong one. You need to find the library that actually does USB output. It is not available through Library Manager.
Remove the one you installed, the correct one is supplied with the IDE, no need to install any.
Update code
Joystick.begin();
Joystick.setThrottle(analogRead(A0)/4);
missdrew:
Are you sure? I tried to compile your example for a Leonardo on Arduino 1.8.13.
sketch_nov17a:1:10: fatal error: Joystick.h: No such file or directory
compilation terminated.
My appologies - While I have never installed the library, someone has on this system.
