my LM75 sensor worked finde on my Arduino Nano Every. Suddenly without changing anything on the code, I got this error message. Can someone help me?
Error message:
In file included from c:\Users\srdja\Documents\Arduino\libraries\Temperature_LM75_Derived-master\src\Temperature_LM75_Derived.h:5:0,
from c:\Users\srdja\Documents\Arduino\libraries\Temperature_LM75_Derived-master\src\Temperature_LM75_Derived.cpp:1:
C:\Users\srdja\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function 'int16_t Temperature_LM75_Derived::readIntegerTemperatureRegister(uint8_t)':
C:\Users\srdja\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:63:12: note: candidate 1: size_t TwoWire::requestFrom(int, int)
size_t requestFrom(int, int);
C:\Users\srdja\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h:61:12: note: candidate 2: virtual size_t TwoWire::requestFrom(uint8_t, size_t)
size_t requestFrom(uint8_t, size_t);
C:\Users\srdja\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function 'uint8_t Generic_LM75_Compatible::readConfigurationRegister()':
C:\Users\srdja\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.8\libraries\Wire\src/Wire.h: In member function 'uint16_t TI_TMP102_Compatible::readExtendedConfigurationRegister()':
Sketch uses 7101 bytes (14%) of program storage space. Maximum is 49152 bytes.
Global variables use 507 bytes (8%) of dynamic memory, leaving 5637 bytes for local variables. Maximum is 6144 bytes.
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
