Given the amount of usage of ThingSpeak and in particular ThingHTTP does any one
know of (or developed ) a 'library' that runs on an Arduino board and connects to ThingSpeak
via an ESP8266.
I have a number of ThingHTTPs working like getting the max temperature and min temperature for my postcode from the BBC weather site. So I receive some 700 odd bytes from a GET command and then need to parse those 700 bytes to find for example 3 chars say 17 degrees (degree symbol is the third char).
Is there such a 'library' that does all ? ... so connects to wifi, checks connection, connects to server, GETs response, parses data based of search parameters.
Searching gives hundreds of results but never what I have described above. They are usually 'send to thingspeak' or assume Arduino is the IDE or some partial bit of non-working code !!! I am sure many others must be doing this but I dont seem to be able to find a solution.
Thanks
