Arduino Lint: False-positive Symlink error due to gitignored node_modules
Hi all :wave:,
I'm developing my first Arduino library. I use arduino-lint as part of a Node.js-based dev setup, where tools like arduino-cli, clang-format, and arduino-lint are downloaded via npm (using a small helper CLI).
My project structure includes a node_modules directory that is .gitignored and will not be published to GitHub or included in the Arduino Library Manager. However, when I run arduino-lint, I get this error:
ERROR: Symlink(s) found. Symlinks cause difficulties for Windows users. These block addition to the Arduino Library
       Manager index:
         /path/to/project/node_modules/.bin/gat
         /path/to/project/node_modules/.bin/mkdirp
       (Rule LS005)
This seems to be a false positive, since these symlinks live under a node_modules/ folder that is explicitly excluded from version control and packaging.
Questions:
1. Is there a way to tell arduino-lint to ignore node_modules/ or respect .gitignore?
2. Is this worth filing as a feature request (e.g., "ignore common development directories like node_modules when checking for symlinks")?
3. What's the current best practice if I want to use Node.js to manage dev tools in my Arduino library project?
My setup:
tree -L 2 -I node_modules .
โ”œโ”€โ”€ arduino-lint
โ”œโ”€โ”€ clang-format
โ”œโ”€โ”€ examples
โ”‚   โ”œโ”€โ”€ DemoServer
โ”‚   โ””โ”€โ”€ WiFiDemo
โ”œโ”€โ”€ library.properties
โ”œโ”€โ”€ LICENSE
โ”œโ”€โ”€ package-lock.json
โ”œโ”€โ”€ package.json
โ”œโ”€โ”€ README.md
โ””โ”€โ”€ src
    โ”œโ”€โ”€ ESP32WiFiCrashUploader.cpp
    โ””โ”€โ”€ ESP32WiFiCrashUploader.h
5 directories, 10 files
cat .gitignore
node_modules
arduino-lint*
clang-format*
npm run lint
> esp32-wifi-crash-uploader@1.0.0 lint
> ./arduino-lint
Linting library in /Users/akoskitta/dev/git/esp32-wifi-crash-uploader
       Manager index:
         /Users/akoskitta/dev/git/esp32-wifi-crash-uploader/node_modules/.bin/gat
         /Users/akoskitta/dev/git/esp32-wifi-crash-uploader/node_modules/.bin/mkdirp
       (Rule LS005)
Linter results for project: 1 ERRORS, 0 WARNINGS
Linting sketch in /Users/akoskitta/dev/git/esp32-wifi-crash-uploader/examples/WiFiDemo
Linter results for project: no errors or warnings
Linter results for projects: 1 ERRORS, 0 WARNINGS
Thank you!
If there is a more appropriate category for asking specifically about the GitHub - arduino/arduino-lint: Tool to check for problems with Arduino projects project, please let me know.
Moved to Allow disabling `LS005` (symlink) and `LS007` (`.exe`) if the file is gitignored ยท Issue #894 ยท arduino/arduino-lint ยท GitHub
