Arduino Low Pass Filter
Hello,
I am designing a low pass filter for my Arduino PID controller. Is it possible to determine what the cutoff frequency should be from the image of the plot I attached? I tried a range of values from the like 5 to 10,000 Hz. None worked. For the PID control I used this code:
#include <util/atomic.h>
// Pins
#define ENCA 2
#define ENCB 3
#define PWM 5
#define IN1 6
#define IN2 7
// globals
long prevT = 0;
int posPrev = 0;
// Use the "volatile" directive for variables
// used in an interrupt
volatile int pos_i = 0;
volatile float velocity_i = 0;
volatile long prevT_i = 0;
float v1Filt = 0;
float v1Prev = 0;
float v2Filt = 0;
float v2Prev = 0;
float eintegral = 0;
  pinMode(ENCA,INPUT);
  pinMode(ENCB,INPUT);
  pinMode(PWM,OUTPUT);
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  attachInterrupt(digitalPinToInterrupt(ENCA),
                  readEncoder,RISING);
  // read the position in an atomic block
  // to avoid potential misreads
  int pos = 0;
  float velocity2 = 0;
  ATOMIC_BLOCK(ATOMIC_RESTORESTATE){
    pos = pos_i;
    velocity2 = velocity_i;
  // Compute velocity with method 1
  long currT = micros();
  float deltaT = ((float) (currT-prevT))/1.0e6;
  float velocity1 = (pos - posPrev)/deltaT;
  posPrev = pos;
  prevT = currT;
  // Convert count/s to RPM
  float v1 = velocity1/70.0*60.0;
  float v2 = velocity2/70.0*60.0;
  // Low-pass filter (25 Hz cutoff)
  v1Filt = 0.12019831*v1Filt + 0.43990085*v1 + 0.43990085*v1Prev;
  v1Prev = v1;
  v2Filt = 0.12019831*v2Filt + 0.43990085*v2 +0.43990085*v2Prev;
  v2Prev = v2;
  //  // Low-pass filter (25 Hz cutoff)
  // v1Filt = 0.6*v1Filt + 0.07*v1 + 0.07*v1Prev;
  // v1Prev = v1;
  // v2Filt = 0.6*v2Filt + 0.07*v2 + 0.07*v2Prev;
  // v2Prev = v2;
  // Set a target
  float vt = 200;
  // float vt = 100*(sin(currT/1e6)>0);
  // Compute the control signal u
  float kp = 5;
  float ki = 10;
  float e = vt-v1Filt;
  eintegral = eintegral + e*deltaT;
  float u = kp*e + ki*eintegral;
  // Set the motor speed and direction
  int dir = 1;
  if (u<0){
    dir = -1;
  int pwr = (int) fabs(u);
  if(pwr > 255){
    pwr = 255;
  setMotor(dir,pwr,PWM,IN1,IN2);
  Serial.print(vt);
  Serial.print(" ");
  Serial.print(v1Filt);
  delay(1);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
  analogWrite(pwm,pwmVal); // Motor speed
  if(dir == 1){
    // Turn one way
    digitalWrite(in1,HIGH);
    digitalWrite(in2,LOW);
  else if(dir == -1){
    // Turn the other way
    digitalWrite(in1,LOW);
    digitalWrite(in2,HIGH);
  else{
    // Or dont turn
void readEncoder(){
  // Read encoder B when ENCA rises
  int b = digitalRead(ENCB);
  int increment = 0;
  if(b>0){
    // If B is high, increment forward
    increment = 1;
  else{
    // Otherwise, increment backward
    increment = -1;
  pos_i = pos_i + increment;
  // Compute velocity with method 2
  float deltaT = ((float) (currT - prevT_i))/1.0e6;
  velocity_i = increment/deltaT;
  prevT_i = currT;
To get the coefficients for the PID control, I used this code: ArduinoTutorials/BasicFilters/Design/LowPass/LowPassFilter.ipynb at main · curiores/ArduinoTutorials · GitHub
Essentially you just take the latter code and input a cutoff frequency which will give you the coefficients you put in the former code. My problem is I don't know how to tell what the cutoff frequency should be from this plot:
Please give us a bigger picture.
I tried 0.5 hz and it worked! nevermind
