Arduino map function for float values
Hello everyone.
My problem is I need something like a map function, but it should return float.
I had an idea about it.
a regular map - function is map(x,a,b,c,d) -->an example ...= map(val,0,1024,0,100);
x is a value that you read by using analogRead() -function
a lower border of the values that analogRead can provide
b upper border of the values that analogRead can provide
c lower border of your value range
d upper border of your value range
my solution is
float z= x/(b-a)*(d-c)+c Note: x,a,b,c and d should be float
Finally the whole function
float map_to_float(float x, float a, float b, float c, float d)
_ float f=x/(b-a)*(d-c)+c;_
  • return f;*
Is it correct? if it do, so i can write a small library if you want
thanks for attention
That formula works only if a is zero. For a general solution, the numerator of the fraction should be (x-a).
thanks a lot
From the map() reference page here http://arduino.cc/en/Reference/Map the map function is just this
long map(long x, long in_min, long in_max, long out_min, long out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
I would assume changing all longs to floats and renaming the mapping function to something like mapf() would work.
Make a template function to be more general?
Old topic but.. like this:
template <class X, class M, class N, class O, class Q>
X map_Generic(X x, M in_min, N in_max, O out_min, Q out_max){
will return x type.
Edit: It have to be put on a header file and #inlcude to compile !
