The following code works and gives me the long long result that i wanted. It isn't pretty, but at least I can move on to other tasks. Thanks to all who helped.
unsigned long long ReceiverFreq = 147165000;
char strfreq[11]; // empty string
char *ptr = strfreq; //
Serial.begin(57600);
ReceiverFreq = ReceiverFreq - 10700000;
ReceiverFreq = ReceiverFreq / 3 ;
//ReceiverFreq = 454883300; // this is what I want to send to my si5351
ltoa(ReceiverFreq, strfreq, 10);
String zeros = "00";
String FinalFreq = strfreq + zeros ;
FinalFreq.toCharArray(strfreq, 11);
ReceiverFreq = char2LL(ptr);
Serial.println("rec freq ");
printULL(ReceiverFreq);
void printULL(unsigned long long value)
if (value == 0)
return;
printULL(value / 10);
Serial.print(int(value % 10));
long long char2LL(char *str)
long long result = 0; // Initialize result
// Iterate through all characters of input string and update result
for (int i = 0; str[i] != '\0'; ++i)
result = result * 10 + str[i] - '0';
return result;
void printULL(uint64_t value) {
if (value) {
for (uint64_t v = 10000000000000000000ull; v; v /= 10) {
if (v <= value) {
Serial.print((int)(value / v % 10));
return;
Serial.print(0);
Less elegant, but nice when you are short on stack space.
int i = 0;
byte myBCD[25];
do
myBCD[i] = value % 10;
value = value / 10;
i++;
while (value != 0);
for (int j = i - 1; j >= 0; j--)
Serial.print(myBCD[j]);
Both you and @johnwasser have used % and / operators to extract the BCD digits and then just print them on the Serial Monitor. I have also used the same operators and the attempt came on the way of trying to understand @jfjlaros and @johnwasser program logic.
A BCD number, by definition, is a 4-bit binary for the decimal digits: 0 to 9. If we want to store them into computer memory, they have to be formatted into 8-bit unpacked (like 00000011 and 00000101) BCD numbers or packed BCD numbers (like 00110101 or 01010011).
65535 (to my eyes it is a decimal number) can be stored in computer memory as:
