Hello,
I am currently working on my first project, where I will be making a distance-measuring turret, that can fire a ball at a certain speed at a target.
But, the problem I have is, that I don't know which mechanism to use for firing the object.
What I am looking for in the mechanism:
*It should be compact
*I should be able to choosing the power at which, the mechanism unloads upon the projectile. So that I deliver the same amount of force to the target regardless of distance. I.e, it doesn't only fire at one speed.
*Reload automatically. I.e not human interference between each winding/loading of power. The actual automatic-ammunition-loading I will incorporate myself
What I have though of myself, so far:
A barrel, much like a gun with a spring inside. The coil will be attached to the end of a servo which is situated horizontally, which in turn is attached to a wheel, that is driven forwards/backwards by a DC motor. The servo will act as the latch mechanism, so that when It goes from 180 to 90-ish degrees the coil will drive the projectile forwards.
Of course, I don't know if this sort of setup will be able to reach the highest velocity compared to say, a crossbow mechanism with a string.
Also, if any of you have any links to guides to choosing coils, I would very much appreciate that
