arduino mega 2560 serial stuck
hey....!
i am using mega 2560, when i connect a 12V-1Amp external power supply , i can'nt access the serial or it does not show the serial port for board.
Please help me...
Do you use the DC jack plug for 12V ?
There are few possibilities:
1 ) The board could be broken. Perhaps the voltage regulator is blown by reverse current. Or you have a bad soldered clone from Ebay. Or you applied 12V accidently somewhere on the Arduino board.
2 ) The voltage regulator reduces the output if it gets too hot. If you use the Arduino board to power a lot of things (like leds) the voltage regulator might get hot. The higher the input voltage, the hotter it gets.
daani:
hey....!
Please help me...
Have you measured the voltages on the Arduino when it's connected?
It would be better to use a 9V external ps because the 12V is forcing the mega onboard regulator to dissipate a lot of extra heat.
