Hey,I have a arduino mega R3 I want to control 6 dc motors in clockwise and anti clockwise directions. I wanted to know if I can connect a l293d motor shield on top of the arduino mega and then I will be able to control 4 motors so then I’m thinking to connect a l298N H bridge but I don’t know how to connect both of them on one arduino mega
Moved your topic to it's current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Rather than a shield, why not get small, cheap L298N driver boards (each can control 2 motors) and then wire them directly to the Mega?
What are the motor specs?
What do you aim to use to power the motors?
The L298 is a bit of a dinosaur for controlling motors these days.
It uses BTJ and drops about 2V when conducting.
You wold be better looking for MOSFET type H-Bridge modules.
Tom...
So I can use 3 l298N with arduino mega?
blh64:
How about… because modern TB6612FNG boards are much more power efficient (little to no voltage drop), smaller (no heat sink, just a flat SMD chip on a small PCB), can handle over 1A without heating up significantly and cost about the same as the old L298N ones?
I HAVE A ARDUINO MEGA I WANTED TO CONTROL 6 MOTORS CLOCKWISE AND ANTI CLOCKWISE 2 ARE 3-6v 140ma 6KPM AND 4 TT DUAL SHAFT MOTORS A LOT OF PEOPLE SAY TO USE 3 L298N SO I WANTED TO KNOW IF IT POSSIBLE TO USE 3 L298N IF NO THEN HOW CAN I CONTROL THE MOTORS?
WHY ARE YOU SHOUTING?
You’ve already had several people tell you, yes you can. What did you not like about those answers?
Steve
Just remember to get a 8-9V power supply with them to compensate for the losses incurred in that H-bridge.
I believe one reason the old L293/L298 modules are still popular is ease of connection, look at a typical L298 module, screw terminals for power and motor connections and pins for push-on signal wires, no
breadboard or soldering needed.
If someone made this module with a TB6612, it would be a hit.
