So I've spent the past few months working on an 8x8x8 led cube, and I've been able to successfully complete it using a regular Arduino Uno. The source code I used was from the same person who created the DIY guide I used to make the cube, and he designed his source code around the Arduino Uno. When I try to upload my code to an Arduino Mega 2560 though, my cube does not work. I do not receive any error messages when I upload my code, the code purely does not work (the cube does nothing). So, what could be causing the code to not upload properly? My suspicion is that there is a command in the setup loop that is compatible with an Atmega 328 micro controller but is incompatible with the Atmega 256[tt][/tt]0. Note: when I test out my code with the Arduino Mega, I hook up all my connectors to the exact same ports that I hook it up to with my Arduino Uno.
The DIY page:
The source code directly from the DIY page:
http://www.instructables.com/files/orig/FNH/V3UU/GICYB47D/FNHV3UUGICYB47D.tmp
The void setup loop, where I suspect the issue lies:
#include <avr/interrupt.h>
#include <string.h>
#define AXIS_X 1
#define AXIS_Y 2
#define AXIS_Z 3
volatile unsigned char cube[8][8];
volatile int current_layer = 0;
int i;
for(i=0; i<14; i++)
pinMode(i, OUTPUT);
// pinMode(A0, OUTPUT) as specified in the arduino reference didn't work. So I accessed the registers directly.
DDRC = 0xff;
PORTC = 0x00;
// Reset any PWM configuration that the arduino may have set up automagically!
TCCR2A = 0x00;
TCCR2B = 0x00;
TCCR2A |= (0x01 << WGM21); // CTC mode. clear counter on TCNT2 == OCR2A
OCR2A = 10; // Interrupt every 25600th cpu cycle (256*100)
TCNT2 = 0x00; // start counting at 0
TCCR2B |= (0x01 << CS22) | (0x01 << CS21); // Start the clock with a 256 prescaler
TIMSK2 |= (0x01 << OCIE2A);
ISR (TIMER2_COMPA_vect)
int i;
// all layer selects off
PORTC = 0x00;
PORTB &= 0x0f;
PORTB |= 0x08; // output enable off.
for (i=0; i<8; i++)
PORTD = cube[current_layer][i];
PORTB = (PORTB & 0xF8) | (0x07 & (i+1));
PORTB &= 0b00110111; // Output enable on.
if (current_layer < 6)
PORTC = (0x01 << current_layer);
} else if (current_layer == 6)
digitalWrite(12, HIGH);
} else
digitalWrite(13, HIGH);
current_layer++;
if (current_layer == 8)
current_layer = 0;
