arduino mega+ enc28j60
buonasera a tutti volevo chiedervi delle delucidazioni a riguardo una scheda arduino mega 2560 e un controller ethernet enc28j60
sto provando questo codice un po spulciato e modificato:
 #include <EtherCard.h>
static byte mymac[] = {
  0x00,0x1A,0x4B,0x38,0x0C,0x5C};
static byte myip[] = {
  192,168,0,220};
byte Ethernet::buffer[700];
boolean RELE1;
boolean RELE2;
boolean RELE4;
void setup () {
  Serial.begin(57600);
  if (!ether.begin(sizeof Ethernet::buffer, mymac, 10))
    Serial.println( "Failed to access Ethernet controller");
    Serial.println("Ethernet controller initialized");
  if (!ether.staticSetup(myip))
    Serial.println("Failed to set IP address");
  ether.hisport=65000;
  pinMode(2, OUTPUT);
  digitalWrite(2, LOW);
  pinMode(3, OUTPUT);
  digitalWrite(3, LOW);
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);
  RELE1 = false;
  RELE2 = false;
  RELE4 = false;
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  Serial.println("Received 1 command");
  if(pos) {
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE1ON") != 0) {
      Serial.println("Received ON command");
      RELE1 = true;
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE1OFF") != 0) {
      Serial.println("Received OFF command");
      RELE1 = false;
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE2ON") != 0) {
      RELE2 = true;
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE2OFF") != 0) {
      RELE2 = false;
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE4ON") != 0) {
      RELE4 = true;
    if(strstr((char *)Ethernet::buffer + pos, "GET /RELE4OFF") != 0) {
      RELE4 = false;
  Serial.println("Received 2 command");
  if(RELE1) {
    digitalWrite(2, HIGH);
  else {
  if(RELE2) {
    digitalWrite(3, HIGH);
  else {
  if(RELE4) {
    digitalWrite(4, HIGH);
  else {
  Serial.println("Received 3 command");
BufferFiller bfill = ether.tcpOffset();
  bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
    "Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
    "<html><head><title>WebLeds</title>"
    "</head><body>"
    "<table  width=\"50%\" height=\"200\" cellpadding=\"1\"cellspacing=\"1\" bordercolor=\"#0000FF\" border=\"5\">"
    "<tr><td>Stato Rele Attuatori </td><td>Comandi</td></tr>"
  if(RELE1 == true)
    bfill.emit_p(PSTR("<tr><td style=\"color: red;\">RELE 1 ON</td><td>"));
    bfill.emit_p(PSTR("<tr><td style=\"color: black;\">RELE 1 OFF</td><td>"));
  if(RELE1 == false)
    bfill.emit_p(PSTR("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE1ON'\"></td></tr>"));
    bfill.emit_p(PSTR("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE1OFF'\"></td></tr>"));
  if(RELE2 == true)
    bfill.emit_p(PSTR("<tr><td style=\"color: red;\">RELE 2 ON</td><td>"));
    bfill.emit_p(PSTR("<tr><td style=\"color: black;\">RELE 2 OFF</td><td>"));
  if(RELE2 == false)
    bfill.emit_p(PSTR("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE2ON'\"></td></tr>"));
    bfill.emit_p(PSTR("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE2OFF'\"></td></tr>"));
   if(RELE4 == true)
   bfill.emit_p(PSTR("<tr><td style=\"color: red;\">RELE 4 ON</td><td>"));
   bfill.emit_p(PSTR("<tr><td style=\"color: black;\">RELE 4 OFF</td><td>"));
   if(RELE4 == false)
   bfill.emit_p(PSTR("<tr><td><input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE4ON'\"></td></tr>"));
   bfill.emit_p(PSTR("<tr><td><input type=\"button\" value=\"clicca qui\"onclick=\"location.href='RELE4OFF'\"></td></tr>"));
  bfill.emit_p(PSTR("</body></html>"));
  ether.httpServerReply(bfill.position());
Serial.println("Received ");
il problema che mi assale e: appena aggiungo il blocco tra i commenti mi si impalla....nel senso che provando a stampare varie stringe per tentare di capire dove si blocca ma alla fine i passaggi li fa tutti solo che non mi carica la pagina web...
codice simile modificato per la ehternet shield R3 mi funzionava tranquillamente....siccome mi cementavo in questo hardware volevo capire se poteva essere un problema hardware o io impedito e mi incasino in qualche passaggio :slight_smile:
grazie per l'aiuto in anticipo
maurizio
probabilmente trovato il problema:
portandolo a 2000 mi carica tranquillamente tutto...
ora provo e vediamo se è stabile
