Hello. I have an Arduino Mega and an ESP32 and I want to send data from the Mega to the ESP32 through the serial communication.
I have uploaded the following code to the Mega:
Serial2.begin(9600);
Serial2.println("Hello");
delay(1500);
and this one to the ESP32:
#define RXp2 16
#define TXp2 17
Serial2.begin(9600, SERIAL_8N1, RXp2, TXp2);
byte n = Serial2.available();
if (n != 0)
Serial.print("Message Received: ");
Serial.println(Serial2.readString());
and everything works fine, but when I insert the ESP32 code in my bigger project I get this in the serial monitor of the ESP32:
Message Received: Hello
and the nothing.
This is the entire code of the ESP32:
#define REMOTEXY_MODE__ESP32CORE_WIFI_CLOUD
#include <WiFi.h>
#include <HTTPClient.h>
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_WIFI_SSID "xxx"
#define REMOTEXY_WIFI_PASSWORD "xxx"
#define REMOTEXY_CLOUD_SERVER "cloud.remotexy.com"
#define REMOTEXY_CLOUD_PORT 6376
#define REMOTEXY_CLOUD_TOKEN "xxx"
#define RXp2 16
#define TXp2 17
//Reflectoare
int LightS = 34; // Fotorezistor
int LightR = 5; // Releu reflectoare
int MotionSensor1 = 16;
int MotionSensor2 = 17;
int MotionSensor3 = 18;
int MotionSensor4 = 19;
int LightStat;
int LightV;
int LightM;
unsigned long onDuration = 90000;// OFF time for LED
unsigned long offDuration = 10000;// ON time for LED
unsigned long rememberTime=0;// this is used by the code
int LEDState = HIGH;
unsigned long IntervalReflectoare = 1000;
unsigned long TimpReflectoare = 0;
unsigned long IntervalReflectoareT = 1000;
unsigned long TimpReflectoareT = 0;
int ContorReflectorT = 0;
//Vant
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 1000; // the debounce time; increase if the output flickers
int pinInterrupt = 35; //senzor vant
int Count = 0;
int Vant;
int VantMax = 0;
//Alarma
int MotionSensor = 21; // Senzor miscare
int MotionSignal = 22; // Semnal sirena
//Ploaie
#define CALC_INTERVAL 1000
#define DEBOUNCE_TIME 15*1000
const int RainSensor = 23;
float TotalVolume = 0;
long NrTips = 0;
long last_micros_rg;
long nextCalc;
long Cronometru;
int PloaieReset;
//Google Sheets
unsigned long IntervalGoogleSheetsVP = 1000;
unsigned long TimpGoogleSheetsVP = 0;
String urlVP;
unsigned long IntervalGoogleSheetsTU = 60000;
unsigned long TimpGoogleSheetsTU = 0;
String urlTU;
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] = // 363 bytes
{ 255,4,0,27,0,100,1,16,30,5,130,1,255,2,65,96,0,31,129,0,
4,251,53,6,0,13,65,117,116,111,109,97,116,105,122,97,114,101,32,99,
117,114,116,101,0,131,1,1,99,21,7,1,13,31,71,101,110,101,114,97,
108,0,130,0,0,2,16,18,1,31,67,6,1,7,7,4,1,135,31,4,
129,0,8,7,4,2,1,135,75,77,47,72,0,129,0,1,3,13,3,1,
8,86,195,162,110,116,32,77,97,120,0,129,0,1,11,13,3,1,8,86,
195,162,110,116,32,76,105,118,101,0,67,6,1,15,7,4,1,135,31,4,
129,0,8,15,4,2,1,135,75,77,47,72,0,130,0,39,2,23,11,1,
31,70,16,40,6,6,6,1,16,135,0,10,50,47,6,14,6,1,0,31,
31,79,78,0,0,79,70,70,0,129,0,42,3,16,3,1,8,82,101,102,
108,101,99,116,111,97,114,101,0,130,0,16,2,23,18,1,31,129,0,22,
3,10,3,1,8,65,108,97,114,109,196,131,0,10,50,25,13,12,6,1,
1,31,31,79,78,0,1,79,70,70,0,70,16,18,13,6,6,1,16,37,
0,130,0,0,20,29,9,1,31,1,2,17,24,11,4,0,31,164,82,101,
115,101,116,0,129,0,11,21,8,3,1,8,80,108,111,97,105,101,0,67,
2,0,25,9,4,0,164,31,6,129,0,9,24,5,3,0,164,76,105,116,
114,105,0,10,50,18,6,19,6,1,1,31,31,65,114,109,97,116,196,131,
0,1,68,101,122,97,114,109,97,116,196,131,0,67,6,40,22,20,5,1,
135,26,11 };
// this structure defines all the variables and events of your control interface
struct {
// input variables
uint8_t Reflectoare_B; // =1 if state is ON, else =0
uint8_t Alarma; // =1 if state is ON, else =0
uint8_t PloaieReset; // =1 if button pressed, else =0
uint8_t Alarma_A; // =1 if state is ON, else =0
// output variables
char Vant_Max[4]; // string UTF8 end zero
char Vant_Live[4]; // string UTF8 end zero
uint8_t Reflectoare_L; // led state 0 .. 1
uint8_t Alarma_L; // led state 0 .. 1
char Litri[6]; // string UTF8 end zero
char text_1[11]; // string UTF8 end zero
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
RemoteXY_Init ();
pinMode(5,OUTPUT);
pinMode(16,INPUT);
pinMode(17,INPUT);
pinMode(18,INPUT);
pinMode(19,INPUT);
pinMode(21,INPUT);
pinMode(22,OUTPUT);
pinMode(23,INPUT);
pinMode(34,INPUT);
pinMode(35,INPUT);
digitalWrite(LightR,HIGH);
//interrupt vant
pinMode( pinInterrupt, INPUT_PULLUP);// set the interrupt pin
attachInterrupt( digitalPinToInterrupt(pinInterrupt), CounterVant, FALLING);
//interrupt ploaie
attachInterrupt(digitalPinToInterrupt(RainSensor), Ploaie, RISING);
//Google Sheets
if (n != 0)
RemoteXY_Handler ();
//START Vant
if ((millis() - lastDebounceTime) > debounceDelay)
lastDebounceTime = millis();
Vant=((Count * 8.75)/100)*3.6;
Count = 0;
itoa (Vant, RemoteXY.Vant_Live, 10);
if (Vant > VantMax) {
VantMax = Vant;
itoa (VantMax, RemoteXY.Vant_Max, 10);
//STOP Vant
//START Reflectoare
if( (millis() - TimpReflectoare) >= IntervalReflectoare){
TimpReflectoare = millis();
LightV = analogRead(LightS);
if (RemoteXY.Reflectoare_B == 1) {
digitalWrite(LightR, LOW);
if (LightV > 900) {
RemoteXY.Reflectoare_L = 1;
if( LEDState == HIGH ){
if( (millis()- rememberTime) >= onDuration){
LEDState = LOW;// change the state of LED
rememberTime=millis();// remember Current millis() time
if( (millis()- rememberTime) >= offDuration){
LEDState = HIGH;// change the state of LED
digitalWrite(LightR, LEDState);// turn the LED ON or OFF
if (digitalRead(MotionSensor1) == HIGH){
digitalWrite(LightR,LOW);
if (digitalRead(MotionSensor2) == HIGH){
if (digitalRead(MotionSensor3) == HIGH){
if (digitalRead(MotionSensor4) == HIGH){
RemoteXY.Reflectoare_L = 0;
if (LightV > 900) {
if( (millis() - TimpReflectoareT) >= IntervalReflectoareT){
TimpReflectoareT = millis();
ContorReflectorT = ContorReflectorT + 1;
itoa (ContorReflectorT, RemoteXY.text_1, 10);
Serial.println(ContorReflectorT);
//STOP Reflectoare
//START Alarma
if (RemoteXY.Alarma_A == 1) {
if (RemoteXY.Alarma == 1) {
digitalWrite(MotionSignal,HIGH);
RemoteXY.Alarma_L = 1;
if (digitalRead(MotionSensor) == 1) {
digitalWrite(MotionSignal,LOW);
RemoteXY.Alarma_L = 0;
RemoteXY.Alarma = 0;
//STOP Alarma
//START Ploaie
Cronometru = millis();
if(Cronometru > nextCalc) {
nextCalc = Cronometru + CALC_INTERVAL;
itoa (TotalVolume, RemoteXY.Litri, 10);
if (RemoteXY.PloaieReset == 1){
NrTips = 0;
TotalVolume = 0;
//STOP Ploaie
//START Google Sheets
//Vant si Ploaie
if( (millis() - TimpGoogleSheetsVP) >= IntervalGoogleSheetsVP){
TimpGoogleSheetsVP = millis();
urlVP += "https://script.google.com/macros/s/";
urlVP += "xxx";
urlVP += "/exec?";
urlVP += "Vant=";
urlVP += String(Vant);
urlVP += "&Ploaie=";
urlVP += String(TotalVolume);
HTTPClient httpPV;
httpPV.begin(urlVP);
int httpResponseCode = httpPV.GET();
urlVP = "";
//Temperaturi si Umiditati
if( (millis() - TimpGoogleSheetsTU) >= IntervalGoogleSheetsTU){
TimpGoogleSheetsTU = millis();
urlTU += "https://script.google.com/macros/s/";
urlTU += "xxx";
urlTU += "/exec?";
urlTU += "Magazie_IN_T=12.2&Magazie_IN_U=50&Magazie_OUT_T=13.3&Magazie_OUT_U=52&Beci_IN_T=14.4&Beci_IN_U=54&Beci_OUT_T=15.5&Beci_OUT_U=56&Solar_T=16.6&Solar_U=58";
HTTPClient httpTU;
httpTU.begin(urlTU);
int httpResponseCode = httpTU.GET();
urlTU = "";
//STOP Google Sheets
} // END LOOP
void CounterVant()
if ( digitalRead(pinInterrupt) == LOW )
Count++;
void Ploaie() {
if((long)(micros() - last_micros_rg) >= DEBOUNCE_TIME) {
NrTips += 1;
TotalVolume = NrTips*(0.00165/0.0055);
last_micros_rg = micros();
Can anyone help me to figure out what is going on?
