Arduino mega + ethernet shield + RJ45 shield
Hello,
i have a question about if the following configuration can work
I recently bought:
  1. Arduino mega 2560
    Development Board compatible with Arduino MEGA 2560 (ATmega2560 + CH340) with 50 cm Cable
  2. Ethernet shield
    Shield Ethernet pentru Arduino W5100 arduino UNO R3 MEGA MEGA1280 2560 328 SD Card, Uno Mega Support, Free RJ45
3.Breakout Shield Mega
Can i combine this 3 components ? kinda want to obtain this - SuperHouse #25: Rack mount Arduino / MQTT light switch controller for home automation - YouTube
Thanks
Do you have the capability of completing that project ?
It sounds as if you don't, if you cannot even chose the components you need.
I can finish the project by buying the arduino that has the RJ45 integrated but i don't wanna spend another 70 dollars on that. I'm trying to combine this 3 components that i have
It should work. The only pins that you can't use for general purpose are the SPI pins (MOSI, MISO and SCLK) and the pin SS pin.
See e.g. Ethernet / Ethernet 2 library
so my configuration will look something like in the picture attached.
  1. arduino
  2. ethernet shield on top of arduino
  3. breakout shield on top of ethernet shield
Yep. Be aware that not all pins of your expansion shield will be able to reach the Mega. For that you need to have the order Mega -> expansion -> ethernet.
But in that case connected wires might interfere with the placing of the ethernet shield on top; I suspect that you need flatcable (IDC) connectors but that might also be to high.
Hi Sterretje,
so i started to integrate the 3 components. This is what i have at the moment.
I still need to make a few connection between Arduino and the upper shield but i don't think i will have a problem.
What do you think ?
