Hi all,
I've been using the code below on an Arduino Uno, but came accros the problem of memory-shortage. Therefore i'm now switched to an Mega2560, but i'm having some trouble with portmappings.
I can't get the rotary encoder to work now, which obviously has something to do with the port mappings.
I've already tried to uncomment these lines:
PCICR |= (1 << PCIE0); // This enables Pin Change Interrupt 0 that covers the Digital input pins of Port B.
PCMSK0 |= (1 << PCINT0) | (1 << PCINT2);
and simultaniously comment these lines:
// uint8_t *pcmask=digitalPinToPCMSK(8);
// PCICR |= (1 << digitalPinToPCICRbit(8) );
// *pcmask |= (1 << digitalPinToPCMSKbit(8)) | (1 << digitalPinToPCMSKbit(10) );
But without any result yet
How can i fix this (probably simple) problem?
Thanks in advance!
Code:
// *************** (3) CONTROL WITH ENCODER ****************************
#elif(_LCDML_CONTROL_cfg == 3)
// settings
#define _LCDML_CONTROL_encoder_pin_a 10 // pin encoder a
#define _LCDML_CONTROL_encoder_pin_b 8 // pin encoder b
#define _LCDML_CONTROL_encoder_pin_button A3 // pin taster
#define _LCDML_CONTROL_encoder_high_active 0 // (0 = low active (pullup), 1 = high active (pulldown)) button
// source Encoder Esc-button · Issue #14 · Jomelo/LCDMenuLib · GitHub
// source: GitHub - mathertel/OneButton: An Arduino library for using a single button for multiple purpose input.
OneButton button(_LCDML_CONTROL_encoder_pin_button, true);
void enter(){LCDML_BUTTON_enter();}
void quit(){LCDML_BUTTON_quit();}
// Global vars for a RoraryEncoder
static int16_t enLast = 0;
int16_t enValue;
int enSteps = 0;
boolean enUp = false;
boolean enDown = false;
// source: GitHub - mathertel/RotaryEncoder: RotaryEncoder Arduino Library
RotaryEncoder encoder( _LCDML_CONTROL_encoder_pin_a, _LCDML_CONTROL_encoder_pin_b );
// The Interrupt Service Routine for Pin Change Interrupt 0
// This routine will only be called on any signal change on D8 and D10: exactly where we need to check.
ISR( PCINT0_vect ) {
encoder.tick(); // just call tick() to check the state.
// setup
void LCDML_CONTROL_setup()
// init pins -> do not need that; it is done in encoder initiation: RotaryEncoder encoder();
//pinMode(_LCDML_CONTROL_encoder_pin_a, INPUT_PULLUP);
//pinMode(_LCDML_CONTROL_encoder_pin_b, INPUT_PULLUP);
button.attachClick( enter );
button.attachDoubleClick( quit );
// Set up pin change interrupt for RotaryEncoder:
// You may have to modify the next 3 lines if using other pins than 8-PB0 and 10-PB2 - PORTB
// please, note both pin 8 and 10 are on the same PORTB and within the same port change interrupt mask
// Pay attention! It may require more lines for mask definition if pins are allocated to different ports.
uint8_t *pcmask=digitalPinToPCMSK( 8 );
** PCICR |= (1 << digitalPinToPCICRbit( 8 ) ); **
__ *pcmask |= (1 << digitalPinToPCMSKbit( 8 )) | (1 << digitalPinToPCMSKbit(10) );__
// alternatively the above 3 lines may be replaced by the following two lines (again, PCINT0 corresponds to PB0 pin 8, PCINT2 - to PB2 pin 10 -> are both in PCMSK0 ) :
// PCICR |= (1 << PCIE0); // This enables Pin Change Interrupt 0 that covers the Digital input pins of Port B.
**// PCMSK0 |= (1 << PCINT0) | (1 << PCINT2); **
// loop
void LCDML_CONTROL_loop()
// check buttons
button.tick();
// check Encoder
enValue = encoder.getPosition();
enSteps = enValue - enLast; // I use enSteps for counting encoder clicks for catching fast rotation in main loop()
if( enValue > enLast ) {
enDown = true;
LCDML_BUTTON_down();
} else if( enValue < enLast ) {
enUp = true;
LCDML_BUTTON_up();
enLast = enValue;
// ******************************* END *********************************
