Arduino Mega Timers / PWM
Hey all,
I'm using an Arduino Mega board, and am incorporating the Tone.h library to play two tones simultaneously (see the "Ugly Details" section):
http://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
I've implemented the code on the Duemilanove without an issue, with timers 1 and 2 being "used up" as a consequence.
However, I was wondering which timers will be "used up" with the same code applied on the Arduino Mega, and which PWM pins will no longer be usable as a result.
I found this site to be somewhat helpful, but wasn't able to determine which timers will be used:
Any help would be greatly appreciated. Thanks in advance!
TRTS
TonyStark:
Hey all,
Back at ya!
Use the Sorce, Luke...
http://code.google.com/p/rogue-code/source/browse/Arduino/libraries/Tone/trunk/Tone.cpp
const uint8_t PROGMEM tone_pin_to_timer_PGM[] = { 2, 3, 4, 5, 1, 0 };
Timers 2 and 3 will be used.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245229578
Ugh. Too many pins. You'll have to find the ones effected. Search for "OC2" and "OC3".
