And I can't figure out how to set the ESP SO HE WILL BE MY WIFI MODULE
In general, what I want to do is to make a type of DATA LOGGER that will receive information FROM TEMP SENSORE AND WILL SEND IT TO https://thingspeak.com/
I have not found on the Internet
how to define that it will send via the built-in ESP
ALL I FOUND ONLINE IS HOW TO DO IT WITH OT A BUILED IN ESP
program the ESP8266 to send data to thingspeak and test it - when it works
program the Mega to acquire the data fromtemperature sensors - when it works
program to mega to send sensor results over Serial3 to the ESP8266
program the ESP8266 to receive the serial data and send it to thingspeak
having to program two microcontrollers and have them communicate with each other is a complication
what is the temperature sensor ? could you connect it to the ESP8266 and forget thr Mega
the ESP8266 could acquire the sensor data and transmit it to thingspeak
so , i did as what the url told me
it upload somthing to the esp
and it ses
" Wrote 264512 bytes (195024 compressed) at 0x00000000 in 17.2 seconds (effective 123.2 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin..."
part 2 ' i have a workinng code ',. for now its only sending the data to the serial monitor
have a look at Programming Wemos Mega + WiFi R3
it takes you thru programming the ESP8266 and the Mega - in particular setting the DIP switches at each stage
