Arduino mega with sim900
it says gsm shield sim900 is compatible with arduino. but is it really compatible with arduino MEGA too ?
if so then should i attach sim900 directly with arduino mega or should i use this method or not? (link below). Since i do not have arduino gsm shield. it is sim900 a third party gsm shield.
my gsm shield sim900:
http://imall.iteadstudio.com/im120417009.html
Thanks for help in advance. I will be thankful if anyone help me out.
Thanks
Ibtisam
Yes it works with the Mega2560. I don't have one but I've been coding for someone who does.
He is using SIM900 and pin 9 for the on pin and pin 10 for the reset.
I can tell you is that the GSM library blocks code execution, sometimes for almost a minute! So don't expect the GSM begin() function to allow other tasks to run at the same time unless you either use the library differently or fix/rewrite it or run the GSM on a dedicated MCU. Otherwise, come time for GSM to connect and run there will be nothing else going on until it lets there be.
It does work though.
