arduino midi drums piezo signal mix with one another
here my program, my arduino board arduino Mega 2560........
(code tags added by moderator)
// User settable variables
unsigned char PadNote[6] = {52,16,66,63,40,65};         // MIDI notes from 0 to 127 (Mid C = 60)
int PadCutOff[6] = {100,100,100,100,100,100};           // Minimum Analog value to cause a drum hit
int MaxPlayTime[6] = {50,50,50,50,50,50};               // Cycles before a 2nd hit is allowed
#define  midichannel	0;                              // MIDI channel from 0 to 15 (+1 in "real world")
boolean VelocityFlag  = true;                           // Velocity ON (true) or OFF (false)
// Internal Use Variables
boolean activePad[6] = {0,0,0,0,0,0};                   // Array of flags of pad currently playing
int PinPlayTime[6] = {0,0,0,0,0,0};                     // Counter since pad started to play
unsigned char status;
int pin = 0;
int hitavg = 0;
// Setup
  Serial.begin(57600);                                  // connect to the serial port 115200
// Main Program
  for(int pin=0; pin < 6; pin++)
    hitavg = analogRead(pin);                              // read the input pin
    if((hitavg > PadCutOff[pin]))
      if((activePad[pin] == false))
        if(VelocityFlag == true)
//          hitavg = 127 / ((1023 - PadCutOff[pin]) / (hitavg - PadCutOff[pin]));    // With full range (Too sensitive ?)
          hitavg = (hitavg / 8) -1 ;                                                 // Upper range
          hitavg = 127;
        MIDI_TX(144,PadNote[pin],hitavg);
        PinPlayTime[pin] = 0;
        activePad[pin] = true;
        PinPlayTime[pin] = PinPlayTime[pin] + 1;
    else if((activePad[pin] == true))
      if(PinPlayTime[pin] > MaxPlayTime[pin])
        activePad[pin] = false;
        MIDI_TX(128,PadNote[pin],127);
// Transmit MIDI Message
void MIDI_TX(unsigned char MESSAGE, unsigned char PITCH, unsigned char VELOCITY)
  status = MESSAGE + midichannel;
  Serial.print(status);
  Serial.print(PITCH);
  Serial.print(VELOCITY);
where is the problem
i am using LoopBe1, Hairless midi and FL studio 11- VST (FPC)
Yes, where is the problem? Your topic title doesn't offer much to go on.
