E-Drum, MIDI code problem
I need help, I have a project for an electric drum, I'm using 27mm piezos, 1Momn resistors and 5.1V Diode Zener, and a Multiplexer, I'm having a problem with one of the pads, where I hit it and it returns the sound it, but with an extra sound from another pad, I've already changed the sensor, I've changed the Arduino channel, I also checked the position and it doesn't touch the other, I came to the conclusion that the problem is in the code, I'm using the MIDI.h library and Hello Drum, can anyone help me?
  EXAMPLE - MUX Sensing
  With this sample code, you can make 16 single piezo pads with a 4067.
  https://github.com/RyoKosaka/HelloDrum-arduino-Library
///////////////////////////////   SETTING VALUE   ///////////////////////////////////
//Determine the setting value.
//By changing the number in this array you can set sensitivity, threshold and so on.
#define Drum_map 0  //0-ADD2, 1-EZD2
byte Note[2][16] = {
  /* _ Hihat tip
    |     _ Kick
    |    |    _ Snare Open hit
    |    |   |    _ Snare SideStick
    |    |   |   |    _ Tom1
    |    |   |   |   |    _ Tom2
    |    |   |   |   |   |    _ Tom3
    |    |   |   |   |   |   |    _ Tom4
    |    |   |   |   |   |   |   |    _ Extra1
    |    |   |   |   |   |   |   |   |    _ Extra2
    |    |   |   |   |   |   |   |   |   |    _ Cym1
    |    |   |   |   |   |   |   |   |   |   |    _ Cym2
    |    |   |   |   |   |   |   |   |   |   |   |    _ Cym3
    |    |   |   |   |   |   |   |   |   |   |   |   |    _ Cym4
    |    |   |   |   |   |   |   |   |   |   |   |   |   |   _ Ride tip
    |    |   |   |   |   |   |   |   |   |   |   |   |   |  |    _ Ride bell
    |    |   |   |   |   |   |   |   |   |   |   |   |   |  |   |       BANK */
  { 51, 36, 38, 42, 71, 69, 67, 65, 47, 96, 77, 79, 81, 89, 60, 61 },  // 0 - ADD2 MAP
  { 20, 36, 38, 37, 47, 48, 41, 43, 45, 1, 55, 49, 57, 52, 51, 53 }    // 1 - EZD MAP
int PAD1[5] = {
  100,  //sensitivity
  5,    //threshold
  20,   //scan time
  35,
  Note[Drum_map][14]
int PAD2[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][5]
int PAD3[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][4]
int PAD4[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][12]
int PAD5[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][0]
int PAD6[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][6]
int PAD7[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][2]
int PAD8[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][11]
int PAD9[5] = {
  100,  //sensitivity
  5,
  20,
  35,
  Note[Drum_map][1]
#include <hellodrum.h>
//Using MIDI Library. If you want to use USB-MIDI, comment out the next two lines.
#include <MIDI.h>
#include <USB-MIDI.h>
USBMIDI_CREATE_DEFAULT_INSTANCE();
//Uncomment the next two lines for using USB-MIDI with atmega32u4 or Teensy
//#include <USB-MIDI.h>
//USBMIDI_CREATE_DEFAULT_INSTANCE();
Mux Breakout ----------- Arduino
S0 ------------------- 2
S1 ------------------- 3
S2 ------------------- 4
S2 ------------------- 5
Z -------------------- A0
//Define MUX Pins
HelloDrumMUX_4067 mux(1, 2, 3, 4, 0);  //D2, D3, D4, D5, A0
//or use two 4501s
//HelloDrumMUX_4051 mux1(2,3,4,0); //D2, D3, D4, A0
//HelloDrumMUX_4051 mux2(5,6,7,1); //D5, D6, D7, A1
//name your pad and define mux pin
HelloDrum pad1(12);
HelloDrum pad2(13);
HelloDrum pad3(14);
HelloDrum pad4(15);
HelloDrum pad5(7);
HelloDrum pad6(9);
HelloDrum pad7(10);
HelloDrum pad8(11);
HelloDrum pad9(8);
  //If you use Hairless MIDI, you have to comment out the next line.
  MIDI.begin(10);
  //And uncomment the next two lines.
  //MIDI.begin();
    mux.scan();
  //or use two 4501s
  //mux1.scan();
  //mux2.scan();
  pad1.singlePiezoMUX(PAD1[0], PAD1[1], PAD1[2], PAD1[3]);
  pad2.singlePiezoMUX(PAD2[0], PAD2[1], PAD2[2], PAD2[3]);
  pad3.singlePiezoMUX(PAD3[0], PAD3[1], PAD3[2], PAD3[3]);
  pad4.singlePiezoMUX(PAD4[0], PAD4[1], PAD4[2], PAD4[3]);
  pad5.singlePiezoMUX(PAD5[0], PAD5[1], PAD5[2], PAD5[3]);
  pad6.singlePiezoMUX(PAD6[0], PAD6[1], PAD6[2], PAD6[3]);
  pad7.singlePiezoMUX(PAD7[0], PAD7[1], PAD7[2], PAD7[3]);
  pad8.singlePiezoMUX(PAD8[0], PAD8[1], PAD8[2], PAD8[3]);
  pad9.singlePiezoMUX(PAD9[0], PAD9[1], PAD9[2], PAD9[3]);
  if (pad1.hit == true) {
    MIDI.sendNoteOn(PAD1[4], pad1.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD1[4], 0, 10);
  if (pad2.hit == true) {
    MIDI.sendNoteOn(PAD2[4], pad2.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD2[4], 0, 10);
  if (pad3.hit == true) {
    MIDI.sendNoteOn(PAD3[4], pad3.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD3[4], 0, 10);
  if (pad4.hit == true) {
    MIDI.sendNoteOn(PAD4[4], pad4.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD4[4], 0, 10);
 if (pad5.hit == true) {
    MIDI.sendNoteOn(PAD5[4], pad5.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD5[4], 0, 10);
  if (pad6.hit == true) {
    MIDI.sendNoteOn(PAD6[4], pad6.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD6[4], 0, 10);
  if (pad7.hit == true) {
    MIDI.sendNoteOn(PAD7[4], pad7.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD7[4], 0, 10);
  if (pad8.hit == true) {
    MIDI.sendNoteOn(PAD8[4], pad8.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD8[4], 0, 10);
  if (pad9.hit == true) {
    MIDI.sendNoteOn(PAD9[4], pad9.velocity, 10);  //(note, velocity, channel)
    MIDI.sendNoteOff(PAD9[4], 0, 10);
It is more likely that the coupling of the sensors is mechanical, and one is triggering the other.
The other thing that can cause that is what is known as cross talk, in the multiplexer. This can happen when some inputs of the multiplexer are left floating (unconnected). So any unused inputs should be connected to ground through a 1K resistor.
Can you make a diagram for this, to put the resistor on input and ground? I don't know how i can do this
Seriously?
I think you ought to question if you are ready to take on such a project yet.
Get a bit of experience first, do some of the examples in the IDE. Play about with the code and the circuits. Try and make things happen and try to understand what to do.
Anyway, you asked so here is the diagram for connecting an input to ground through a 1K resistor:-
resistor
I did that, it didn't work, so I tried it with an arduino mega that I had, and I noticed that, every time I move from the A7 analog input, from the A8, it starts to do the same thing, even if all analogues from A7 down are only with one input
