Arduino Mini Sumo
Buenas!!, necesito que alguien me ayude a modificar este código para que mi robot funcione para una competencia de mini sumo adjunto e codigo aqui:
#include <Servo.h>
#include <Servo.h>
Servo myservo;
int Echo_Pin=A0;  // ultrasonic module   ECHO to A0
int Trig_Pin=A1;  // ultrasonic module  TRIG to A1
#define Lpwm_pin  5     //pin of controlling speed---- ENA of motor driver board
#define Rpwm_pin  6    //pin of controlling speed---- ENB of motor driver board
int pinLB=2;             //pin of controlling turning---- IN1 of motor driver board
int pinLF=4;             //pin of controlling turning---- IN2 of motor driver board
int pinRB=7;            //pin of controlling turning---- IN3 of motor driver board
int pinRF=8;            //pin of controlling turning---- IN4 of motor driver board
volatile int D_mix;
volatile int D_mid;
volatile int D_max;
volatile int Front_Distance;
volatile int Left_Distance;
volatile int Right_Distance;
volatile int Right_IR_Value;
volatile int Left_IR_Value;
float checkdistance() {
  digitalWrite(Trig_Pin, LOW);
  delayMicroseconds(2);
  digitalWrite(Trig_Pin, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(Echo_Pin, HIGH) / 58.00;
  delay(10);
  return distance;
void Detect_Left_and_Right__distance() {
  myservo.write(180);
  delay(400);
  Left_Distance = checkdistance();
  delay(600);
  Serial.print("Left_Distance:");
  Serial.println(Left_Distance);
  myservo.write(0);
  delay(400);
  Right_Distance = checkdistance();
  delay(600);
  Serial.print("Right_Distance:");
  Serial.println(Right_Distance);
  myservo.write(90);
void Ultrasonic_obstacle_avoidance()
  Front_Distance=checkdistance(); //obtain the value detected by ultrasonic sensor
  if((Front_Distance < 20)&&(Front_Distance > 0))//if the distance is greater than 0 and less than 20
    stopp();//stop
    delay(100);
    myservo.write(180);
    Left_Distance=checkdistance();//measure the distance
    delay(100);
    myservo.write(0);
    Right_Distance=checkdistance();//measure the distance
    delay(100);
if(Left_Distance > Right_Distance)//if distance a1 is greater than a2
      rotate_left(150);//turn left
      myservo.write(90);
      delay(300);
    else //if the right distance is greater than the left
      rotate_right(150);// turn right
      myservo.write(90);
      delay(300);
  else//otherwise
    go_forward(100);//go forward
void Obstacle_Avoidance_Main()
  Ultrasonic_obstacle_avoidance();
void setup(){
  myservo.attach(A2);
  D_mix = 10;
  D_mid = 20;
  D_max = 100;
  Front_Distance = 0;
  Left_Distance = 0;
  Right_Distance = 0;
  myservo.write(90);
  pinMode(Echo_Pin, INPUT);
  pinMode(Trig_Pin, OUTPUT);
  pinMode(pinLB,OUTPUT); // /pin 2
  pinMode(pinLF,OUTPUT); // pin 4
  pinMode(pinRB,OUTPUT); // pin 7
  pinMode(pinRF,OUTPUT);  // pin 8
  pinMode(Lpwm_pin,OUTPUT);  // pin 5 (PWM)
  pinMode(Rpwm_pin,OUTPUT);  // pin 6(PWM)
void loop(){
  Obstacle_Avoidance_Main();
void go_forward(unsigned char speed_val)    // speed_val:0~255
    {digitalWrite(pinRB,HIGH);
     digitalWrite(pinRF,LOW);
     digitalWrite(pinLB,HIGH);
     digitalWrite(pinLF,LOW);
     analogWrite(Lpwm_pin,speed_val);
     analogWrite(Rpwm_pin,speed_val);
void go_backward(unsigned char speed_val)    // speed_val:0~255
     digitalWrite(pinRB,LOW);
     digitalWrite(pinRF,HIGH);
     digitalWrite(pinLB,LOW);
     digitalWrite(pinLF,HIGH);
void rotate_left(unsigned char speed_val)        // speed_val:0~255
     digitalWrite(pinRF,LOW );
void rotate_right(unsigned char speed_val)    // speed_val:0~255
void stopp()        //stop
Componentes:
Ultrasonic Module, L298N Driver Board, Remote, IR Control for Arduino UNO DIY Kit
Creo que debes mostrar una imagen de tu robot. Además, debes mostrar qué es lo que está fallando. No soy muy bueno en español ni en codificación, pero para que otros te ayuden con esto, lo haría. También podrías escribir en inglés y español. Además, el mini sumo es realmente genial, buena suerte en tu competencia. ¿Fue esto útil o no?
He trasladado su tema de una categoría de idioma inglés del foro a la categoría International > Español @mau7 .
En adelante por favor usar la categoría apropiada a la lengua en que queráis publicar. Esto es importante para el uso responsable del foro, y esta explicado aquí la guía "How to get the best out of this forum".
Este guía contiene mucha información útil. Por favor leer.
De antemano, muchas gracias por cooperar.
Moderador:
Por favor, lee las Normas del foro
Si posteas en el foro en inglés usa idioma inglés para expresarte, eso incluye los comentarios de tu código. Si un código tiene comentarios en español también moverán tu hilo a esta sección en Español.
Si escribes en español debes usar el foro Arduino en español
He revertido tu hilo a la versión en la que el moderador @pert tuve que mover el mismo a este foro Internacional en Español.
Ten mas cuidado la próxima mas y no hagas cambios cuando ya se han tomado acciones.
Llegan las compentencia de Mini Sumo y todos con el mismo problema, porqué no son mas previsores y lo hacen con tiempo.
Como ya te dijo @1102cool indica que pasa. Puedes grabar un video, subirlo a youtube y compartir el link aquí e intenta explicar que ocurre.
Además si puedes un esquema del hardware ayudaría a entender. Tu lo tienes delante, lo diseñaste o copiaste pero nosotros no sabemos nada.
Lee las normas del foro por favor, como ya te he pedido, esto es para que mejores el contexto del problema y se entienda tu pregunta.
