Arduino mkr 1010 wifi problem
I have purchased new arduino mkr wifi 1010 board last 7 days I amtrying to dump the code unfornutely I am getting error while dumping anyone could please me in this issue.
Arduino: 1.8.19 (Windows 10), Board: "Arduino MKR WiFi 1010"
Sketch uses 30544 bytes (11%) of program storage space. Maximum is 262144 bytes.
Global variables use 3216 bytes (9%) of dynamic memory, leaving 29552 bytes for local variables. Maximum is 32768 bytes.
An error occurred while uploading the sketch.
and only one time code is dumped but unfortunetly I am not able to open the serial monitor and force clsoed by the arduino IDE . (Sketch uses 32224 bytes (12%) of program storage space. Maximum is 262144 bytes.
Global variables use 3364 bytes (10%) of dynamic memory, leaving 29404 bytes for local variables. Maximum is 32768 bytes.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Mar 19 2018 09:45:14
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.839 seconds
Write 32224 bytes to flash (504 pages)
[==============================] 100% (504/504 pages)
done in 0.248 seconds
Verify 32224 bytes of flash with checksum.
Verify successful
done in 0.030 seconds
CPU reset.)
Please anyone help me with this regards ..
I don't know what that means, I am going to assume it mean you want to upload the code.
What you have posted does not show the actual error. Please try to upload again and this time use the copy error button and then paste the entire error here.
Also post your code.
Copy_error_button
No device found on COM15
Error while setting serial port parameters: 115,200 0 8 1
java.lang.Exception: Programmer not responding
Make sure that FirmwareUpdater sketch is loaded on the board.
at cc.arduino.plugins.wifi101.flashers.java.FlasherSerialClient.hello(FlasherSerialClient.java:108)
at cc.arduino.plugins.wifi101.flashers.java.WINCFlasher.updateFirmware(WINCFlasher.java:55)
at cc.arduino.plugins.wifi101.UpdaterImpl$2.run(UpdaterImpl.java:234)
at cc.arduino.plugins.wifi101.flashers.java.WINCFlasher.uploadCertificates(WINCFlasher.java:106)
at cc.arduino.plugins.wifi101.UpdaterImpl$3.run(UpdaterImpl.java:301)
at cc.arduino.plugins.wifi101.UpdaterImpl$2.run(UpdaterImpl.java:234) this is the error.
are you sure COM15 is the correct port?
run the Windows device manager, expand Ports COM & LPT
as you unplug/plugin the MKR does COM15 disappear/appear
what board did you have selected under Tools>Board? should be Arduino MKR WiFi 1010
This may help:
Ensure that you use a good quality data USB cable to connect the board to your pc. Reset your board ( Bootloader mode (double-press)) and upload a sketch (Blink) to it when in this mode. Use IDE 2.1.0 that will auto detect your board.
