Good evening to all, I write because and for some time I have problems with the MKR GSM 1400 module.
The problem I have is the following, I can connect my module, I can select the port and everything, I compile the program and it doesn't give me any error, when I go to load it it disconnects from the computer and reconnects itself and I get this error message:
Sketch uses 33668 bytes (12%) of program storage space. Maximum is 262144 bytes.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Oct 4 2017 08:53:16
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.828 seconds
Write 34228 bytes to flash (535 pages)
[=== ] 11% (64/535 pages)
[======= ] 23% (128/535 pages)
[========== ] 35% (192/535 pages)
[============== ] 47% (256/535 pages)
[================= ] 59% (320/535 pages)
[===================== ] 71% (384/535 pages)
[========================= ] 83% (448/535 pages)
[============================ ] 95% (512/535 pages)
[==============================] 100% (535/535 pages)
done in 0.226 seconds
Verify 34228 bytes of flash with checksum.
Verify successful
done in 0.035 seconds
CPU reset.
The module that came to me has no antenna and no external battery.
My question and the following one, it's possible that the problem is due to the fact that I don't have the battery and when I go to charge the program I have a momentary Reset? on the other modules it never happened to me, the program seems right to me and it's the same as those provided by arduino...
To eliminate the battery problem I tried to power the module on the GND and on VIN but it disconnects anyway...
Has anyone had anything like this happened before? Do you know how to solve this problem?
Good evening to all and I hope that someone can help me...
I also put the code I use, maybe it can help:
// include the GSM library
#include <MKRGSM.h>
//#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
#define SECRET_PINNUMBER ""
const char PINNUMBER[] = SECRET_PINNUMBER;
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("SMS Messages Receiver");
// connection state
bool connected = false;
// Start GSM connection
while (!connected) {
if (gsmAccess.begin() == GSM_READY) {
connected = true;
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.println("Waiting for messages");
int c;
// If there are any SMSs available()
if (sms.available()) {
Serial.println("Message received from:");
// Get remote number
sms.remoteNumber(senderNumber, 20);
Serial.println(senderNumber);
// An example of message disposal
// Any messages starting with # should be discarded
if (sms.peek() == '#') {
Serial.println("Discarded SMS");
sms.flush();
// Read message bytes and print them
while ((c = sms.read()) != -1) {
Serial.print((char)c);
Serial.println("\nEND OF MESSAGE");
// Delete message from modem memory
sms.flush();
Serial.println("MESSAGE DELETED");
Do you have in mind when you connect your phone to the computer and if you have the volume turned on does it make sounds? and you also get notification that the device is connected...
When I load the program my MKR GSM 1400 does the same thing, it never happened to me with any other arduino I connected.
And then the message I published above comes out in orange...
The connection cable is an original SAMSUNG and anyway my computer recognizes the card.
He always does the same thing, I do not understand why he does a reset of the CPU, in the program I do not tell him to do it ... To someone and already happened?
Lo sketch usa 33676 byte (12%) dello spazio disponibile per i programmi. Il massimo è 262144 byte.
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
done in 0.825 seconds
Write 34236 bytes to flash (535 pages)
done in 0.211 seconds
Verify 34236 bytes of flash with checksum.
Verify successful
CPU reset.
Error downloading http://downloads.arduino.cc/packages/package_staging_index.json.
In the last line of information it says CPU reset but I don't understand why it does a reset, I in the program don't tell you, it does it so randomly...
There is probably an issue with a partially downloaded json. This could happen if there is an incomplete json file for the board manager in Arduino Data folder
I’d say remove the SAMD install, trash the IDE and reinstall the ide from latest version download and look to spyware (Cf this discussion)
The code is loaded on the board because actually the LED blinks, when I go to write more complex programs but does not make me go the serial monitor...
I don't understand why it does all those operations for such a simple program, I tried to download different versions of arduino, I uninstalled it, I tried everything but that message always comes out. Does anyone have other solutions? If I can not solve this problem I can not advance with the project and are already several days that I am blocked ...
Thanks a lot to everyone and have a nice day
The problem is that I do not see anything on the serial monitor, I removed the code to the sim and at the moment there are about 2 fr so the credit is sufficient.
#include <MKRGSM.h>
// PIN Number
GSM gsmAccess;
GSM_SMS sms;
while (!Serial) {
// connection state
if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
connected = true;
int c;
sms.flush();
sms.flush();
Is it right how I define the PIN? since I removed it by reading in the various forums recommend to put this:
I don't know where I'm wrong... This is the first time I've used this module and I'm in enough trouble.
so it works...
as for Arduino Create Editor I do not know what it is, I would like to make the program as simple as possible I need to read a message and just send it.
If I don't use Arduino Create Editor, how do I change the program?
I'm trying to make a program that makes me see on the serial monitor a message that I send him through another phone, once done this program I make do to go on.
I read that you can save important data such as phone number, PIN and so on in a folder but honestly I do not need all this security, can you tell me how to delete parts that I do not need?
Thank you and I wish you a good evening
Mozzini97:
"Arduino Create Editor" (more commonly called "Arduino Web Editor") is a cloud based alternative to the Arduino IDE:
Mozzini97:
Just like you would any other sketch. The only relevant difference between the Arduino IDE and the Arduino Web Editor in this particular case is that the the Arduino Web Editor has a more "pointy-clicky" approach to the "Secret Tab", as I already explained to your in your previous thread:
pert:
The idea behind arduino_secrets.h is that you define all your private information in that file so that you can share the main sketch file without revealing private information. Many people have accidentally shared information they didn't intend to with their code and had to scramble to change passwords, etc. before some ne'er-do-well uses it for malicious purposes. In fact, black hat hackers are constantly running scans of the Internet looking to harvest information from these types of leaks.
The Arduino Web Editor has a feature that makes it very easy to share your sketches via "Share URLs" and when you do that the arduino_secrets.h file is automatically cleared so anyone viewing your shared sketch won't be able to see your private information and instead can define their own information in the file. In the Arduino Web Editor, the file will be shown as a tab named "Secrets" with a form to fill in the information, which then generates the #define directives for the macros. Anytime you write a name in your sketch in the Arduino Web Editor that starts with "SECRET_", a new field is added to the Secret tab.
In the Arduino IDE, the file will be shown as a tab named arduino_secrets.h and you will find the standard #define directives there.
However, that's not even really relevant here because you commented out the #include directive for arduino_secrets.h in your sketch, so you're not even using the "Secret Tab" feature.
