Hello,
I have been looking around for a good Modbus RTU library. I finally found
I noticed others were struggling to get AdvancedHMI to talk with Arduino.
I built a test Sketch and test AdvancedHMI project where I read and write coils. Read and Write to Registers.
Modbus is a little esoteric, so I would like to post the AdvancedHMI project and the Arduino sketch somewhere.
Stuff I struggled with
-Finding a library that included Coils, most were just Holding Registers
-Installing Modbus library, was getting not valid library. Had to unzip folder then rezip folders on level above library.
-You can write Signed Ints into Holding Registers
-Unsigned Ints are Modbus standard but AdvancedHMI had to use a "U"prefix infront of PLCAddress
-Figuring out that Holding Register of 0 in Arduino code mapped to 40001 in Advanced HMI
-New people to Modbus might not know that sometimes you have to guess at the Offset and you need to know that Coils are at 0xxxx, Holding Registers at 4xxxx
- I recommend go get the Modbus-Aruduino library by Andre
- Download latest AdvancedHMI
- Get qModbus, as debug tool(watch out all registers are 0 based, function code takes care of 0x or 4x)
- Run Andre's example, prove to yourself that you can read and write coils into Library example, using qModbus
- Follow AdvancedHMI instructions on how to build solution, setup comm port, etc
Then borrow any ideas from my attached sketch
I will post my AdvancedHMI solution to google drive with link later
ModbusRTUAdvancedHMI.ino (2.45 KB)
