Hy!
I want to thest the Modbus communication protocoll betwen two arduino based board.
The circuit and the connection is ok, I tested with another package type communication and its worked.
Now I want to use modbus.
I tryed to write on master side an holding register and on the slave side I want to read.
The MAX481 ic RE and DE pin is connected to 6 and 7 pin.
The master code:
#include <ArduinoRS485.h> // ArduinoModbus depends on the ArduinoRS485 library
#include <ArduinoModbus.h>
#define RE 6
#define DE 7
int counter=0;
while (!Serial);
pinMode(RE,INPUT);
pinMode(DE,INPUT);
digitalWrite(RE,LOW);
digitalWrite(DE,LOW);
// start the Modbus RTU client
if (!ModbusRTUClient.begin(9600)) {
Serial.println("Failed to start Modbus RTU Client!");
while (1);
void loop(){
writeHoldingRegisterValues();
counter++;
delay(5000);
void writeHoldingRegisterValues() {
// set the Holding Register values to counter
digitalWrite(RE,HIGH);
digitalWrite(DE,HIGH);
ModbusRTUClient.holdingRegisterWrite(42,4,counter);
// Alternatively, to write a single Holding Register value use:
// ModbusRTUClient.holdingRegisterWrite(...)
The slave code:
#include <SoftwareSerial.h>
#define RE 6
#define DE 7
SoftwareSerial mySerial (4, 5);
const int numHoldingRegisters = 10;
mySerial.begin(9600);
while (!Serial);
pinMode(RE,INPUT);
pinMode(DE,INPUT);
// start the Modbus RTU server, with (slave) id 42
if (!ModbusRTUServer.begin(42, 9600)) {
Serial.println("Failed to start Modbus RTU Server!");
while (1);
ModbusRTUServer.configureHoldingRegisters(0x00, numHoldingRegisters);
// poll for Modbus RTU requests
ModbusRTUServer.poll();
// map the holiding register values to the input register values
for (int i = 0; i < numHoldingRegisters; i++) {
long holdingRegisterValue = ModbusRTUServer.holdingRegisterRead(i);
mySerial.println(holdingRegisterValue);
Can somebody help me do what i do wrong?
Thanks!
Benji
UPDATE: Modified the master and slave code.
Modbus RTU Server LED
This sketch creates a Modbus RTU Server with a simulated coil.
The value of the simulated coil is set on the LED
Circuit:
- MKR board
- MKR 485 shield
- ISO GND connected to GND of the Modbus RTU server
- Y connected to A/Y of the Modbus RTU client
- Z connected to B/Z of the Modbus RTU client
- Jumper positions
- FULL set to OFF
- Z \/\/ Y set to OFF
created 16 July 2018
by Sandeep Mistry
const int ledPin = LED_BUILTIN;
mySerial.println("Modbus RTU Server LED");
// start the Modbus RTU server, with (slave) id 1
if (!ModbusRTUServer.begin(1, 9600)) {
mySerial.println("Failed to start Modbus RTU Server!");
while (1);
// configure the LED
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// configure a single coil at address 0x00
ModbusRTUServer.configureCoils(0x00, 1);
// read the current value of the coil
int coilValue = ModbusRTUServer.coilRead(0x00);
if (coilValue) {
// coil value set, turn LED on
digitalWrite(ledPin, HIGH);
// coild value clear, turn LED off
Modbus RTU Client Toggle
This sketch toggles the coil of a Modbus RTU server connected via RS485
on and off every second.
Circuit:
- MKR board
- MKR 485 shield
- Y connected to A/Y of the Modbus RTU server
- Z connected to B/Z of the Modbus RTU server
- Jumper positions
- FULL set to OFF
- Z \/\/ Y set to ON
by Sandeep Mistry
// while (!Serial);
mySerial.println("Modbus RTU Client Toggle");
mySerial.println("Failed to start Modbus RTU Client!");
while (1);
// for (slave) id 1: write the value of 0x01, to the coil at address 0x00
if (!ModbusRTUClient.coilWrite(1, 0x00, 0x01)) {
mySerial.print("Failed to write coil! ");
//mySerial.println(ModbusRTUClient.lastError());
}else{
mySerial.println("ON");
// wait for 1 second
// for (slave) id 1: write the value of 0x00, to the coil at address 0x00
if (!ModbusRTUClient.coilWrite(1, 0x00, 0x00)) {
}else{
mySerial.println("OFF");
This works, the LED go ON and OFF but
ModbusRTUClient.coilWrite(1, 0x00, 0x01); -----> return 0
:o :o
It is very interesting...
