I need to generate two PWM signals at 100Hz.
I wrote something like this:
PWM
#define PROVAL_RFR_RATE 100 // In Hz
#define PROVAL_TOP_VAL (uint16_t)(1000000L / PROVAL_RFR_RATE)
int proval[2];
InitPWM();
PROVAL (Proportional Valve)
void InitPWM() {
TCCR1A |= (1<<WGM11); // phase correct mode & prescaler to 8
TCCR1A &= ~(1<<WGM10);
TCCR1B &= ~(1<<WGM12) & ~(1<<CS10) & ~(1<<CS12);
TCCR1B |= (1<<WGM13) | (1<<CS11);
ICR1 = PROVAL_TOP_VAL;
pinMode(9, OUTPUT); TCCR1A |= (1<<COM1A1); // pin 9 PROVAL 1
pinMode(10, OUTPUT); TCCR1A |= (1<<COM1B1); // pin 10 PROVAL 2
provalWrite();
void provalWrite() {
OCR1A = proval[0]; // pin 9
OCR1B = proval[1]; // pin 10
I have just a few questions:
- Is my basic code correct?
- In this mode what is the minimum value to obtain 0% PWM and maximum value to obtain 100% PWM output?
Thank to all.
