How to modify this code to make the serial monitor update the value. I have used similar code with the SoftwareSerial library with Arduino Uno and Maga2560. but when I use the following code with Arduino Nono 33 Iot, the serial monitor show results as in the picture
#include <Arduino.h>
#include "wiring_private.h"
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define RE 8
#define DE 7
// Modbus RTU requests for reading NPK values
const byte nitro[] = {0x01,0x03, 0x00, 0x04, 0x00, 0x01, 0xC5, 0xCB};
const byte phos[] = {0x01,0x03, 0x00, 0x05, 0x00, 0x01, 0x94, 0x0B};
const byte pota[] = {0x01,0x03, 0x00, 0x06, 0x00, 0x01, 0x64, 0x0B};
// A variable used to store NPK values
byte values[1];
Uart mySerial (&sercom0, 2, 3, SERCOM_RX_PAD_1, UART_TX_PAD_0);
// Attach the interrupt handler to the SERCOM
void SERCOM0_Handler()
mySerial.IrqHandler();
// Reassign pins 5 and 6 to SERCOM alt
pinPeripheral(2, PIO_SERCOM_ALT);
pinPeripheral(3, PIO_SERCOM_ALT);
// Start my new hardware serial
mySerial.begin(4800);
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
display.clearDisplay();
display.setCursor(25, 15);
display.setTextSize(1);
display.setTextColor(WHITE);
display.println(" NPK Sensor");
display.setCursor(25, 35);
display.print("Initializing");
display.display();
delay(3000);
byte val1,val2,val3;
val1 = nitrogen();
delay(250);
val2 = phosphorous();
delay(250);
val3 = potassium();
delay(250);
Serial.print("Nitrogen: ");
Serial.print(val1);
Serial.println(" mg/kg");
Serial.print("Phosphorous: ");
Serial.print(val2);
Serial.print("Potassium: ");
Serial.print(val3);
delay(2000);
display.setTextSize(2);
display.setCursor(0, 5);
display.print("N: ");
display.print(val1);
display.print(" mg/kg");
display.setCursor(0, 25);
display.print("P: ");
display.print(val2);
display.setCursor(0, 45);
display.print("K: ");
display.print(val3);
display.display();
byte nitrogen(){
digitalWrite(DE,HIGH);
digitalWrite(RE,HIGH);
delay(10);
if(mySerial.write(nitro,sizeof(nitro))==8){
digitalWrite(DE,LOW);
digitalWrite(RE,LOW);
for(byte i=0;i<7;i++){
//Serial.print(mod.read(),HEX);
values[i] = mySerial.read();
Serial.print(values[i],HEX);
return values[4];
byte phosphorous(){
delay(10);
if(mySerial.write(phos,sizeof(phos))==8){
return values[4];
byte potassium(){
delay(10);
if(mySerial.write(pota,sizeof(pota))==8){
return values[4];
