I have an Arduino Nano, powered by USB. When by itself on the desk, attached to nothing but the USB cable the pins have the following values
-5V pin reads 4.62V
-AREF pin reads 4.62V
-3.3V pin read 3.32V
My plan is to connect to an accelerometer that requires 3.3V and outputs 0-3.3V (actually 1.65 +/-1.65V).
To get the most resolution from the ADC, I was going to connect the AREF and 3.3V pins and use the EXTERNAL reference.
However when I connect 3.3V and AREF pins, (I have not connected the sensor, just the two pins) the pin voltages are as follows:
-5V pin reads 4.62V
-3.3V pin read 4.62V
Why does AREF read 4.62V with nothing connected? Why does 3.3V pin rise to match the AREF and 5V pin voltages?
If you want to use AREF you need set the registers to disable Vcc as a reference.
septillion:
I thought that was accomplished by analogReference(EXTERNAL). No? Yes?
It does, but I never read you did
Let alone do I read you don't do an analogRead() before calling analogReference().
Quote from the Arduino reference:
If you’re using an external reference on the AREF pin, you must set the analog reference to EXTERNAL before calling analogRead(). Otherwise, you will short together the active reference voltage (internally generated) and the AREF pin, possibly damaging the microcontroller on your Arduino board.
septillion:
adwsystems:
I don't use analogRead. I use the ISR method from Nick's website. But I haven't added that yet because
If you're using an external reference on the AREF pin, you must set the analog reference to EXTERNAL before calling analogRead(). Otherwise, you will short together the active reference voltage (internally generated) and the AREF pin, possibly damaging the microcontroller on your Arduino board.
The sensor is not 5V tolerant and wanted to make sure the ADC and the 3.3V output was working right. Needless to say I was a little surprised when it wasn't.
Perhaps my code would help
analogReference(EXTERNAL);
septillion:
Why?
Does using analogRead() instead of the ISR solve the issue?
Might. We would have to compare the code the OP has and the analogRead() code.
septillion:
Why is my MCVE broken as well. No ISR and no analogRead()?
I tried this with an UNO and got the same result.
