I have an arduino nano and I know that the digital outputs work with 3.3v and I have a relay that activates only with 5v.
The question is what can I do to provide the voltage needed to activate the relay coil.
Thank You Guys!!
Thank You Guys!!
Hi and welcome to this forum.
Where did you get this information?
All of my Nanos work with 5V and all of the I/O pins are 5V types; the Nano has only one 3.3V pin, but this is not programmable as I or O.
Nevertheless, even if your Nano would come with 3.3V output, pls use a suitable transistor (e.g. NPN type S9014 (45V/100mA) to switch the relay. AND: don't forget the kickback diode parallel to the relay to avoid killing electronics.
