Hello, I have a problem running the ENC28J60 in conjunction with the arduino nano. I run the pings sketch from the EtherCard.h library, and nothing happens. The only thing that serial monitor shows is "[pi" and if I disconnect the CS pin it only shows "[pings]". I've tried everything, separate power supply for ECN, different libraries, different sketches, connecting via ICSP and normally via pins. Nothing helps.
// Ping a remote server, also uses DHCP and DNS.
// 2011-06-12 <jc@wippler.nl>
// License: GPLv2
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
// called when a ping comes in (replies to it are automatic)
static void gotPinged (byte* ptr) {
ether.printIp(">>> ping from: ", ptr);
void setup () {
Serial.begin(57600);
Serial.println("\n[pings]");
// Change 'SS' to your Slave Select pin, if you arn't using the default pin
if (ether.begin(sizeof Ethernet::buffer, mymac, 10) == 0)
Serial.println(F("Failed to access Ethernet controller"));
if (!ether.dhcpSetup())
Serial.println(F("DHCP failed"));
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
#if 1
// use DNS to locate the IP address we want to ping
if (!ether.dnsLookup(PSTR("www.google.com")))
Serial.println("DNS failed");
#else
ether.parseIp(ether.hisip, "74.125.77.99");
#endif
ether.printIp("SRV: ", ether.hisip);
// call this to report others pinging us
ether.registerPingCallback(gotPinged);
timer = -9999999; // start timing out right away
void loop () {
word len = ether.packetReceive(); // go receive new packets
word pos = ether.packetLoop(len); // respond to incoming pings
// report whenever a reply to our outgoing ping comes back
if (len > 0 && ether.packetLoopIcmpCheckReply(ether.hisip)) {
Serial.print(" ");
Serial.print((micros() - timer) * 0.001, 3);
Serial.println(" ms");
// ping a remote server once every few seconds
if (micros() - timer >= 5000000) {
ether.printIp("Pinging: ", ether.hisip);
timer = micros();
ether.clientIcmpRequest(ether.hisip);
I'm using this code, all I changed is the CS pin to 10
