Arduino nano ESP32 + ESC BLDC motor control
When trying to control the esc with PWM from servo library it only lets me control 2 out of the 4 escs, It only generates the PWM signal to 2 out of 4 digital pins. How do I fix this?
#include <ESP32Servo.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
Servo esc1;
Servo esc2;
Servo esc3;
Servo esc4;
int throttle1;
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
struct Data_Package{
  byte roll;
  byte pitch;
  byte throttle;
  byte yaw;
Data_Package data;
unsigned long lastReceiveTime = 0;
unsigned long currentTime = 0;
  Serial.begin(57600);
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setAutoAck(false);
  radio.setDataRate(RF24_2MBPS);
  radio.setPALevel(RF24_PA_LOW);
  radio.startListening();
  esc1.attach(6);
  esc2.attach(5);
  esc3.attach(4);
  esc4.attach(3);
void loop(){
  if (radio.available()) {
    radio.read(&data, sizeof(Data_Package));
    lastReceiveTime = millis();
  currentTime = millis();
  if ( currentTime - lastReceiveTime > 1000 ) {
  throttle1 = map(data.throttle,90,180,1000,2000);
  esc1.writeMicroseconds(throttle1);
  esc2.writeMicroseconds(throttle1);
  esc3.writeMicroseconds(throttle1);
  esc4.writeMicroseconds(throttle1);
  Serial.println(throttle1);
Can be an insufficient power supply.
I have a 11.1V lipo 3s battery connected to each motor, that isnt the problem.
Have the ESCs all got a GND connection that is common with the ESP32 board ?
Yes, they do.
If you swap the connection to a working ESC and a non working ESC does the problem stay with the ESC or the pin ?
When I swap the connections the other 2 that were working stop working and the 2 that werent working now spin. I dont think there is a problem with pins or the esc, for some reason the arduino nano esp32 wont give 4 signals at the same time.
Fixed the problem. I used Deneyap Servo library.
